High-beam Ground no longer working. Anyone know why?
The ground on the body harness connector for the headlight seems to be screwed up. It isn't lose or pulled out at all but if I ground to anything else the high beams will work. Is there something simple I am missing here????
They are both no working. Started with drivers side and then passenger side went putting it back together after diagnosing. I may cut the body harness ground and see if it is the connector. And then run a ground to the inside of the light on the HID. I don't want have to start cutting stuff. Has any got any ideas?
Not sure
I'm not sure, I'm having an issue with my low beam hid. They won't come on. I'm thinking it's the ground in the hid not connected though, not sure. I hope you figure something out.
