Vaccuum line diagrams?
Im trying to clean up some messy procharger install stuff from previous owner.
i believe the original spot for pcv hose was on the plenum(not the one on top left that goes to haltech).
currently there is a vacuum log on that nipple for gauge and something else. The pcv hose goes pcv to back by throttle body... but not on plenum which doesnt see right.
just trying to see how it was supposed to be
put up pictures...I'm not following
Are you 100% it goes to (and hooks up to the throttle body? or just that area? There's a nipple on the back side of the valve cover right back there. There are ports on the TB but it's a coolant line.
its not on the throttle body just goes back that way... my wording could have been misleading
I believe this is what is where pcv is supposed to route into the manifold... instead it has a vacuum log on it.
the pcv hose now routes to the back of intake manifold by firewall. I assume it works fine like this, but i know its not correct.
