Clutch disengagement issue need help!
Old May 7, 2026 | 08:31 PM
Rhy's Avatar
Rhy
Default Clutch disengagement issue need help!
So I went to drive my 350z after winter was over and parked it for a week while I did a wrap job, once it was done I wasn’t able to shift into any gear I’ve gotten a new clutch and new slave cylinder and still having the same issue can someone give me a hand on what it could be?
clutch was installed properly, car is a 2006, old clutch pressure plate had broken fingers checked the pedal adjustment and it’s good I’m clueless on what it can be
Old May 7, 2026 | 09:26 PM
icer5160's Avatar
icer5160
Are you getting good travel on the clutch fork/slave cylinder? Have you thoroughly bled the clutch hydraulics? Are you able to shift gears with the engine off?
-Icer
Old May 7, 2026 | 09:34 PM
Rhy's Avatar
Rhy
-Icer
Travels far enough and no air in the system , shifts perfectly fine when engine is off
Old Yesterday | 05:27 AM
Heel Til I Die's Avatar
Heel Til I Die
What replacement clutch did you use?
Have you verified the master cylinder is functioning correctly?
If you still have the OEM spider's nest clutch hard lines, it is extremely easy for air to still be trapped in the system even though you're getting bubble-free fluid out during the bleeding process.
Old Yesterday | 10:36 AM
Rhy's Avatar
Rhy
I have a new z1 clutch
master seems to be working just fine
i I do still have the oem lines can continue bleeding and see if anything will loosen up
Old Today | 09:40 AM
iideadeyeii's Avatar
iideadeyeii
This happened to me when my clutch release fork pivot ball snapped. Happened shortly after a clutch swap; it's like an $8 dealer part and I would always recommend to change it with the clutch swap
NectarOfTheGods
Yesterday 02:28 PM
Heizuke
Jul 28, 2020 02:22 PM
350DaysAyear
Jul 15, 2020 08:59 PM
JSTR
Jan 28, 2011 04:05 PM
Car vs. Driver
Mid-Atlantic
Aug 6, 2008 08:21 AM
