New 350z owner here - electrical noises from rear wheels at idle. Any ideas?
Old Jun 16, 2026 | 12:28 PM
r3m's Avatar
r3m
Unhappy New 350z owner here - electrical noises from rear wheels at idle. Any ideas?
Does anyone have any clues as to what is causing the noise in this video?? It sounds like some sort of electrical static or almost like when you peel tape off a tape roll lol. It only happens when the engine is running and can be heard most notibly from around both rear wheels while at idle, it doesn't change with RPM, or change when I turn the AC or radio on/off - I pulled the boot out and while I can hear it, its still not as loud as when I am down by the rear wheels - but it does look like someone has put sound deadening all over the boot area
The car is running fine with no codes etc - its a 2007 350z HR GT on 63k miles
Thanks all!
Old Jun 16, 2026 | 12:36 PM
frenzee's Avatar
frenzee
I can't hear anything. Could you post a longer video from the area where it's the loudest?
Old Jun 16, 2026 | 12:39 PM
r3m's Avatar
r3m
Will try to get a better video tomorrow - if you listen very carefully/turn up the volume, you can definitely hear it in that video - its a very inconsistent staticy noise like tzz tz tz ttzzz tzz tz
Old Jun 16, 2026 | 01:48 PM
frenzee's Avatar
frenzee
Sorry, but I turned the volume all the way up, on headphones, and I still can't hear what you're describing. The only electrical thing back there is the fuel pump (and the tail lights and the rear wiper, of course). There is nothing high-voltage back there. Maybe the evap canister??? But AFAIK, that thing doesn't have an electrical component.
Old Jun 17, 2026 | 05:18 AM
Heel Til I Die's Avatar
Heel Til I Die
I can't really hear any noise either. Maybe a hissing exhaust leak? These cars aren't exactly the quietest running machines out there.
Old Jun 17, 2026 | 06:29 AM
bre240z's Avatar
bre240z
I dont hear anything
Old Jun 17, 2026 | 11:22 AM
r3m's Avatar
r3m
Maybe I need to get my hearing checked or something..
Old Yesterday | 11:33 AM
frenzee's Avatar
frenzee
If I may suggest, try to locate the source of the noise first. Use a vacuum hose, one end to your ear, and hunt for the source with the other end. In other words, use it as a stethoscope. Once you locate it, turn on the recording on your phone and get a good 15-30 second clip, and then while still recording, back away from that spot so we can tell what area that was.
dajmiacc
Jan 30, 2025 10:18 PM
Arod_562
Dec 4, 2023 09:41 AM
Bmurray350z
Oct 10, 2011 04:05 PM
Caprice270
Aug 21, 2007 02:40 PM
