FS: Stillen License Plate Bracket
Price:$SOLD!
For sale is a used Stillen license plate bracket for the Nissan 350z that use the 22mm tow hook. This fits the 2006-2008 models for sure but it may also fit 2004-2005 models as well (also fits the 2008-2009 Sentra 2.0L). I would check with Stillen before purchasing because I purchased this model for my 2006 Nissan.
Item is in good condition with some minor surface rust that won't show once your license plate is mounted. Basically you screw this into your tow hook area and apply some loctite.
The small bolt/nuts that come with the bracket are lost so you will need to supply your own hardware to mount the license plate to the bracket. Fairly simple to do, a trip to the hardware store and $1.50 should solve fix that.
