CHARLOTTE area Z-Car can't pass inspection. HELP!!!
Old Mar 21, 2007 | 07:09 AM
  #41
buzzardmountain's Avatar
buzzardmountain
Luis, might want to edit the shop name out of a public forum......you never know who's watching.....lol
Old Mar 21, 2007 | 07:15 AM
  #42
reptile718's Avatar
reptile718
Your right
This is prob. why I shouldn't post at work my mind is in three different places at once, didn't even think about it.
Changed, thanks for the heads up!
Old Mar 21, 2007 | 07:43 AM
  #43
unkn0wn ryder's Avatar
unkn0wn ryder
damn tooo bad you're in NC.... lolthe guy that did my inspections in tx lol... all he did was down the block and back, looked under the hood and made sure all my lights worked..... btw my "service engine soon" light was on and uhhh... i got 2% tints... oh yeah you can smell my exhuast fumes and can tell that my car runs rich.... lol
mike
Old Mar 23, 2007 | 02:18 PM
  #44
imonlykidden's Avatar
imonlykidden
haha, well jeesh louis. i thought i had told YOU!!!!!
hurry it up man, we need it bad.
Thanks to everyone for helping out. the horn will be fixed all it was was a crimped wire... thanks again to all..
-kevin
Old Mar 24, 2007 | 11:06 AM
  #45
nathanwl2004's Avatar
nathanwl2004
damn dude I'll bet you were sweatin bullets when that cop pulled you.
just about everything that can be illegal on you car pretty much is... I like it
Old Mar 25, 2007 | 07:07 AM
  #46
imonlykidden
i was legal then, my inspection was due Feb. i was pulled FeB. this sucks.
Damnit louis let go with it.
Old Mar 25, 2007 | 07:28 AM
  #47
genegoesfast's Avatar
genegoesfast
What code are you throwing due to the emanage? If it's engine coolant temp low (p0128) you just need to cut the wire spliced in that feeds the emanage that info. I had the same problem. I also ran non-foulers on test pipes and didnt throw a code. With your mods you should be able to run code-less. The airbag light might be your only problem. Fix the codes, not the inspection.
Old Mar 25, 2007 | 10:00 AM
  #48
imonlykidden
^^^^ were are running the check engine light b/c of the e-manage.
Old Mar 25, 2007 | 10:01 AM
  #49
imonlykidden
It comes in and off everyone in a while...The light will be on some days it will be off.. haha weird.
i just want to be safe and get it done by someone who doesnt care, and doesn't report me or soemthing.
Old May 12, 2007 | 07:28 AM
  #50
ncdoc's Avatar
ncdoc
Not to hijack thread...
Will test pipes pass inspection here (with no codes)?? I was wondering if tey do a visual inspect.
ncdoc
Old May 12, 2007 | 03:08 PM
  #51
imonlykidden
the car will not pass emmisions with test pipes. i had to take mine off and i'm still having problems with getting inspected. and its been 3 months.
This is some bull****, i need it done before Zdayz.
Old May 14, 2007 | 03:49 AM
  #52
buzzardmountain
I thought you were getting it done at Derek's???
Let me call my guy and see what happens.....it might mean a short road trip for ya.
Old Nov 2, 2008 | 05:46 PM
  #53
TSG-Z's Avatar
TSG-Z
I seriously need help, my inspection was up in JULY, check engine light stays on and I'm throwing 3 codes:
NATS
Cylinder misfire
fuel pump sensor
Someone help me please, I know with the amount of FI cars in NC there has to be someone!
Bump
Old Nov 3, 2008 | 03:40 AM
  #54
imonlykidden
What number cylinder # is the misfire?
Hit me up on AIM (imonlykidden) sometime, i might be able to help. with knowing what you need to do that is.
Old Nov 3, 2008 | 06:44 AM
  #55
str8dum1's Avatar
str8dum1
no one will pass you with codes becuase they cant. a computer is hooked up. u gotta get those codes cleared!
NATS
Cylinder misfire
fuel pump sensor
Bump
Old Nov 3, 2008 | 07:01 AM
  #56
imonlykidden
Yeah they can't anymore. but you have one code you can fail. but the check engine light can't be on.
Am i wrong?
Old Nov 4, 2008 | 10:25 AM
  #57
03Platinum350z's Avatar
03Platinum350z
Go back to stock
j3ff
Old Nov 4, 2008 | 03:15 PM
  #58
imonlykidden
Negative SLOW poke.
Old Nov 6, 2008 | 08:57 AM
  #59
TSG-Z's Avatar
TSG-Z
I was told that using different plugs may clear the misfire, the NATS, I'm kinda confused about and the fuel sensor also.
Old Nov 7, 2008 | 06:57 AM
  #60
imonlykidden
I was told the same thing. So i got those top of the line ones, still did not fix it. Came to be Cylinder 6 misfire, was my number 6 piston rings were shot. B.c it went away when it was replaced. I'm good on inspection now.
So this might help the other guy who is having a misfire problem.
nanotech
Oct 2, 2015 05:02 AM
D_Rod
Sep 29, 2015 04:42 AM
