Coilover shock preload help in Phoenix
Old Aug 29, 2013 | 05:59 PM
scottG35's Avatar
scottG35
Default Coilover shock preload help in Phoenix
Hey guys!
After installing my Tein coilover's on my G35 I started hearing/feeling all sorts of strange noises. A buddy of mine determined it's probably because I haven't preloaded them correctly. If anyone in the Phoenix/Chandler area that's willing to take a look at it with me I'd greatly appreciate it.
Thanks in advance!
Old Sep 3, 2013 | 04:46 PM
cmedrive's Avatar
cmedrive
Jack the car up and see if the spring comes unseated when the shock is at full droop. If it does then you will probably need spring tenders to make up the difference or longer springs. That's probably the noise you're hearing.
Did you buy the setup as a complete set with springs? Are you sure you have the correct size spring for the perches? Is this a used setup? If it's new your dealer can help you with the setup.
Stevo Z
Oct 3, 2015 09:14 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
