I need help my Z got spray painted!!!
Old Oct 9, 2006 | 06:46 AM
350zpl's Avatar
350zpl
Default I need help my Z got spray painted!!!
i need to find some1 good to fix my paint on my Z
on the way to work this morning i was making a turn and some ******* left a spraypaint bottle on the street it was dark and i didnt c it and i ran over it . The can exploded sparying over my baby's percious white paint (passenger side) breaking my heart and f*** up my day.Now i got a green spraypaint on the bottom skirt and some o the rear and under body do u guys know any1 who can buff it out plz i want my baby to be clean again
Old Oct 9, 2006 | 07:27 AM
350zjanet's Avatar
350zjanet
Use a really LIGHT rubbing abrasive compound......... For example....... The
3M Perfect- It Rubbing Compound I think you can ask some of the guys a Pep boys what they think of this product......
http://www.superiorcarcare.net/3mperllrubco.html
Good Luck!
Old Oct 9, 2006 | 08:18 AM
350zpl's Avatar
350zpl
thnks ill try that
Old Oct 9, 2006 | 08:27 AM
Vertex350's Avatar
Vertex350
You can also try to clay bar it first. Not too long ago, CalTrans was painting the white divider line on my street. I ran it over and got some paint along my sideskirts and door. I used clay bar and it all came off.
Old Oct 9, 2006 | 08:31 AM
350Zteve's Avatar
350Zteve
WD40 does wonders for removing overspray. I would try this first. Second I would try 3M POLISHING compound. This is not nearly as abrasive as rubbing compound, which I would leave as your last resort.
Old Oct 9, 2006 | 11:44 AM
clean's Avatar
clean
If nothing else works try goof-off/oops cleaning formula, but make sure you polish after or it will leave a faded look.-thats what we use at Toyota.
Old Oct 9, 2006 | 11:49 AM
350zz053's Avatar
350zz053
claybar should work....if not bring it to a shop, they can buff it out for sure...goodluck bro
Old Oct 9, 2006 | 02:23 PM
THE TECH's Avatar
THE TECH
The only problem I see with doing it yourself, is that some products can be considered "light" as Janet mentioned, but if you have no experience using them, you can end up burning through your clear. I'd suggest using a good body shop and just having them buff it out for you. Will save you headaches and time and will come out showroom new. Since you are in Costa Mesa, I suggest using:
Doctor Detail
2011 Placentia Ave.
Costa Mesa
949/650-0204
Old Nov 8, 2006 | 06:26 PM
mr. sparco's Avatar
mr. sparco
Someone maliciously sprayed my car with spray can paint when I was in college. I had a detailer come out and the guy removed it all. Costed 115 bucks. He had a special cleaner that cleaned it all off. He then buffed, polished and waxed it. Car looked great afterwards.
Old Nov 8, 2006 | 06:30 PM
ClaytonC01's Avatar
ClaytonC01
nail polish remover may work too
Old Nov 9, 2006 | 04:00 PM
mikeg8r's Avatar
mikeg8r
If you are going to try this yourself, I would start with the least aggressive method first and then work my way up. I would probably start with claybar and a lot of lube. If that doesn't work, maybe wd40 or goo gone. You'll def need to clean and wax after that and there is a possibility you could haze your finish. If that happens you'll need to buff and polish and then wax. If that doesn't work, I would stop and seek a professionals help. Why not try asking at http://www.meguiarsonline.com or http://www.autopia.org I think a lot more professional detailers will read it there than here. Good luck.
edit: ouch, old thread. So what did you do? how did it end up?
kyin
Oct 15, 2015 05:54 AM
Cashwin
Oct 1, 2015 06:36 AM
