FS: headunit/amp/speakers
Old Feb 23, 2007 | 10:33 PM
suhster85's Avatar
suhster85
Default FS: headunit/amp/speakers
(2) used Audiobahn AS65C 120 watt speakers $35
Condition: Good. The highs and lows are still extremely clear
These are relatively inexpensive speakers but they still sound great. They were in the car when I purchased them, and paired with this amp, the bass and treble were both awesome. I'm not sure what size speakers they are, but they are from an S2000 door.
(1) used Phoenix Gold XS4600 Amplifier $300
Condtion: Good. No scratches and the connectors are in good condition.
Specifications:
4 Channel Mosfet Amplifier
PWM Mosfet Power Supply Defeatable
Advanced Overload and Thermal Protection
Dual Hi Level Input Connections
Input Sensitivity Control
Advanced Muting Circuitry Eliminates Turn-On And Turn-Off Noises
Metal Film Capacitors/Resistors In Signal Path
24kt Gold Plated High Current Power And Speaker Terminals
Isolation Mounting Feet Optional
XS Link For Seamless Multiple Amplifier Installation
Dual Low Pass level control
Frequency Response +/-1dB, 20Hz to 20 kHZ
Signal to Noise Ratio (A-weighted) >100dB
Max Continuous Bridged Power @ 1% THD 300 watts x 2 into 4 ohms @ 14.4 Vdc
Max Continuous Power per Channel @ 1% THD 150 watts x 4 into 2 ohms @ 14.4 Vdc
Nominal Continuous Power per Channel @ 1 % THD 75 Watts x 4 into 4 ohms @ 14.4 Vdc
IASCA/USAC Power Rating 25 Watts x 4 into 4 ohms @ 12.5 Vdc
Minimum Load when Bridged 2 Ohms
Minimum Load per Channel 1 Ohm
Input Signal Voltage Range 0.1 volts to 2 volts
Crossover Type Resistor Network, Linkwitz, Highpass/Lowpass
Crossover Slope 24 dB per octave
Crossover Frequency Range 20-550Hz
Factory Crossover Setting 85Hz
Auxilary Output Channels 2
Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Rear
Bass Boost 0- to +18dB @ 45 hZ
Power Supply Voltage 10Vdc to 15.5Vdc
Recommended Fuse 60 amp
Dimensions 14.25L x 9.25W x 2.10H
(1) like new Alpine CDE 9846 Headunit $140
Condition: Excellent. This headunit is basically brand new. I got it as a xmas present and then a few days later I totaled my car so it was only in the car for a few days. THIS PLAYS MP3 CD's
Specifications:
http://www.alpine-usa.com/US-en/products/p...6&lang=en&tab=F
I AM IN NEED OF MONEY RIGHT NOW SO I WILL SELL THEM ALL TOGETHER FOR $350 IF YOU BUY IT BY FEB. 26
PLEASE EMAIL ME AT daniel@julianpyun.com AS I DO NOT VISIT THE FORUMS OFTEN.
Thanks,
Daniel
Old Feb 24, 2007 | 12:10 AM
Boneout JZA80's Avatar
Boneout JZA80
Shine Auto Project
daniel? S14 daniel? julians homie? its me Ben, supra/ Zguy... waddup bro
bump for a good guy
Old Feb 24, 2007 | 02:08 PM
suhster85's Avatar
suhster85
bump for a good guy
Hey Ben,
Yea its me, Julian's friend. How you doing man? I hear you are also friends with Rick. Anyway, thanks for the bump.
Old Feb 24, 2007 | 09:02 PM
Boneout JZA80
Shine Auto Project
Originally Posted by suhster85
Hey Ben,
no worries yeah hes the homie whats up with you now?
good luck selling your stuff do you still have the S14? hows julian havent seen him in ages, ive been wanting to hit up the track with him
Old Feb 26, 2007 | 05:34 PM
suhster85's Avatar
suhster85
thanks man. the s14 has been gone for a while. I picked up an S2K but some drunk driver ran a red light in front of me and now its totaled.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
