Rear Camber Kit install..
I just got the spc rear camber kit and I just wanted to know if it is a difficult install or if anyone knows of a reputable shop in the IE area with a reasonable price who can do it..thanks!!
oh and any info on an alignment shop in the area wouldnt hurt either
rear camber bar is pretty easy. just make sure you have the tools and enough leverage- they can be on pretty tight-
just besure before you take off the stock bar- mark the orientation of the stock adjustment bolts and measure the length of the SPC bar to match-
installing is pretty simple but the purpose of the install on that part is to adjust the camber, if you install it without adjusting it your camber could be much worse and you could be driving around wearing the hell out of the tires. If you install it to save the install price, then hurry to the alignment place to get it aligned before you drive on your tires too much with the wrong adjustment.
many places will install them cheap $40-60 and will do the alignment right after
^^ ya. after i did mine i drove it right away to get an alignment.
anywho OP- it should take no more than 30 minutes on each side if your only installing the camber. i jus did mine (well my friend did) like two weeks ago- and it is a fairly simple job
i've been reading in other threads about having to elongate the slot where the bolt goes. did any of you have to do that? here's the link:
http://turboneticsownersclub.com/tur...oltinstall.pdf
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
