Help.. I Have Radiator Fluid Everywhere...
Old Apr 26, 2008 | 12:07 AM
jubes's Avatar
jubes
Default Help.. I Have Radiator Fluid Everywhere...
Ok guys, I seriously need your opinions on my situation... I've already posted this on the engine mod area, I'm hoping someone in here might have an answer...
For the past week, I've been hearing my cooling fan running continuously even when I'm running.. doesn't sound right to me, so I was planning on calling the dealer Monday since it's Friday afternoon and they are probably closed.
I drive down the freeway and I'm getting back from the movies and getting out of my car when I notice liquid all over the place... and it's comming from my car... I notice the smell of radiator fluid... and behold it is.
So I open my hood, and I notice the FREAKING COOLANT IS FILLED TO THE TOP OF THE CANISTER. WTF?!?!!?!?
Is this the reason why my fan has been running all the time? and the reason why my car is taking a leak on my driveway? Anybody have an answer? All suggestions or answers will be appreciated. Please help...thank you for hearing me vent.
Old Apr 26, 2008 | 02:33 AM
Sensi09's Avatar
Sensi09
Works Concepts
Well you obviously overheated, and this could be due to a number of reasons.
-bad thermostat
-water pump
-may need to bleed it
-there is some type of blockage
-or it could be the fan itself
Old Apr 26, 2008 | 02:34 AM
Sensi09's Avatar
Sensi09
Works Concepts
Oh and if you care about the appearance of you engine bay, I'd clean off the coolant asap as it's going to stain.
Old Apr 26, 2008 | 06:00 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Pubes,
you should get this checked out asap
Old Apr 26, 2008 | 06:29 AM
jubes's Avatar
jubes
Thanks guys... I'm actually taking it to the dealership right now.. I was able to get an appointment @ 8am... so I'll keep you posted.
Old Apr 26, 2008 | 03:58 PM
jubes's Avatar
jubes
Just to keep you guys posted...
My freaking radiator blew...
They didn't give me any details on why it did, but that they have to keep it til monday so they can order the part... this sucks... I'm taking that the continuous fan running was a hint to the radiator... but I just had the 30,000 major service done, and they flushed the radiator when they did that. So if my radiator was going bad.. shouldn't they have caught that?
ehh.. we'll never know..
Old Apr 26, 2008 | 04:27 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Good luck with everything. I'm sure it will all work out.
It is possible they overlooked the problem during the 30K service, but the problem more than likely started after the fact.
Old Apr 26, 2008 | 05:30 PM
Sensi09's Avatar
Sensi09
Works Concepts
Are they replacing the radiator? Might as well upgrade to a koyo radiator while you're at it. It should cost around $400.
http://www.stillen.com/product.asp?i...SAN&model=350Z
If they flushed it at the last service, they may not have bled it correctly, which could cause your problems. As for the fan constantly running, that could be due to a bad fan or a bad thermostat.
Old Apr 26, 2008 | 10:31 PM
jubes's Avatar
jubes
Thanks for the support. They probably did overlook it, which sucks. I feel naked without my Z...
Yeah, they have to replace it. His words were "Bro, your radiator is fried.." so yeah, it didn't sound good. That radiator is sure a beauty... I have to start thinking about upgrading the internals before I do anything external...
headers? exhaust? FI? hehehe.. I sure do love the blow off valves.. LOL
Old Apr 28, 2008 | 08:48 AM
4DC's Avatar
4DC
The fan is running because the the temp sensor s reading hot because the cooling system was probably not bled correctly as was mentioned before. Not uncommon for the Z because of the process of bleeding the system (not easy). The other possible major problem is how long were you driving while overheating, could there be head gasket damage. I would say that I am almost certaint hat there isn't anything wrong with the fan, just air pockets in the cooling system. If your radiator blew the overflow tank would be empty not full.
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
SharX59
Sep 30, 2015 10:54 AM
