DG-5 Suspension Kit Info?
Old May 5, 2008 | 05:52 AM
lastblueprint's Avatar
lastblueprint
Question DG-5 Suspension Kit Info?
Has anyone heard about DG-5 Suspension Kit? Just wondering if anyone has ran these on the street besides Chris Forsberg @ Formula D. here is a couple things i saw in some site, let me know what you guys think.
http://www.dg-5.co.jp/
http://www.driftspeed.com/index.php?main_page=dg_5
Experience a new dimension of capabilities for grip or drift.
Lead by Keiichi Tsuchia, suspension specialists developed DG-5, and it was the beginning of a legacy.
"If you change your suspension, it must be fun to drive afterwards."
"With driving techniques evolving we must constantly be able o adapt to stay victorious"
"DG-5 gives that edge to be triumphant even against the toughest of rivals"
Keiichi "Drift King" Tsuchiya
During the design, testing, and re-designing of these products, the DG-5 team adopted these words as guiding principles. To this day we still adhere to these maxims. Although power is important, the true key to better lap times in circuit racing lies in the suspension of the vehicles. DG-5 was created to cheer on those drivers who continually strive to be the best. DG-5 products are designed to bring out your full potential to raise you to victory
The DG-5 suspension kit was designed and tested by the Drift King Tsuchiya himself in collaboration with Swing Springs for drift and high level racing.
Features
- 30 Step damper adjustable
- Enhanced strength utilising a 50/60mm diameter cylinder
- Superior strength steel bracket with urethane
- Adjustable upper mounts for applicable models
- Additional helper/traction spring for improved tractability
- Highest quality Swift 65mm springs
Note
- Please specify spring rate for custom kits in the order comments
- More information and pictures available from the DG-5 website.
- Full specification and other models available from the DG-5 website.
Old May 6, 2008 | 12:43 AM
Boneout JZA80's Avatar
Boneout JZA80
Shine Auto Project
just curious what intentions you did have because you totally sound like a vendor such as your last suspension post regarding the same matter?
https://my350z.com/forum/southern-california/310124-kbee-performance-suspension.html
its just your whole post sounds like an advertisement so im a bit confused not calling you out or anything just totally curious
and to answer your question i do not know anyone who ran that setup yet sorry dood
Old May 6, 2008 | 05:38 AM
lastblueprint
Naw, I was just wondering if anyone has heard about these Coilovers, all the info that i put on my last post was the only info i got from the Diffrent website, Im not a vendor nor trying to promote anything or anyone, just put up the post to see if anyone has these coilover set up, where they from? Are they good quality and who here in My350z has them? Thats all, my bad if there was misunderstood. I guess i need to be a little more clear, my bad guys. So what's up are these any good?
Old May 6, 2008 | 12:48 PM
Boneout JZA80
Shine Auto Project
cool bro, upon reading what you posted regarding the DG-5 i wouldnt doubt their quality since many Japanese companies take pride and are disciplined with their R & D..like what ive seen with Tomei
good luck though either way if you have the money id get them
Old May 6, 2008 | 01:53 PM
lastblueprint
coo thanks man, yeah i did a lil bit more research on them, and they are suppose to be the next big thing, plus they are using Swift Springs. Zeal use to use Swift Springs, till about 2 years ago. Swift Had a great set up but was only offered in the UK and Japan, but had 2 sets of coilovers here with Colin @SWIFT SPRING in ontario. Yeah thanks man, well if anyone runs them give us any type of updates. As the the Kbee's they work best with the Swift Spring helpers, it makes the ride quality much comfortable. Thank man!
Old May 6, 2008 | 02:06 PM
tanman8181's Avatar
tanman8181
Read this:
http://www.zilvia.net/f/showthread.p...highlight=dg-5
Old May 6, 2008 | 02:52 PM
lastblueprint
Wow, sounds good. I did a little bit of research and a couple of the D1 driver are running this set up, and have been for the last couple years for the r&d. For the last couple of years the top drivers in the competition have been running these coilovers. Almost all the D1 driver use Swift Springs on there car’s. Good R&D and the Swift Spring set up make a killer Coilover, just like when Zeal had Swift on the coilovers. Thanks for the feed back. It does seem that these are worth it and are great quality.
350Z_Al
Oct 29, 2020 07:44 PM
