Clean up my headlights?
Old Feb 15, 2011 | 05:25 PM
LaoSiFu's Avatar
LaoSiFu
Default Clean up my headlights?
I want to get my headlight buff and polish. Can anyone recommend anyone local you can sand, polish and rebuff? Thanks!!!
~Robert
Old Feb 15, 2011 | 06:30 PM
VolkZ's Avatar
VolkZ
i had mine done at USA autoglass in riverside, it's almost been a year and it's still clear.
VolkZ's Avatar
VolkZ
i think it was like $25
Old Feb 15, 2011 | 06:32 PM
r_seng's Avatar
r_seng
What the cheap.
Old Feb 15, 2011 | 06:55 PM
3508EVO's Avatar
3508EVO
Robert, there is no need to take it to a detailing shop. All u need to do is buff each headlight with a lil bit off Crest pro health toothpaste and scratch out liquid chemical they sell at Auto zone D make sure to grab a buffing pad before you walk out the storeD
Old Feb 15, 2011 | 07:17 PM
Anomaly's Avatar
Anomaly
I'd offer to clear up your headlights for you but I haven't gone as far as wetsanding the lenses yet.
So far, I've had really good results with either:
1. Meguiar's PlastX - Good for semi-routine cleaning of contamination build up.
2. Machine polish - done when I detail the entire vehicle.
Is it bad enough to have to wet sand? If it's not too far gone, a couple applications of PlastX should work.
Old Feb 15, 2011 | 09:49 PM
advancetek's Avatar
advancetek
there is more kits now available i used the turtle wax kit brings 4 wet sanding pads level 1-4 depending how bad how bad your lights are just got to be careful and not overdue it.
Old Feb 16, 2011 | 08:59 AM
RedlineRedZ33's Avatar
RedlineRedZ33
try headlight restoral (innovative detailing). it's my buddy's dad who runs the business, and he buffs, polishes, UV coats your headlights so it doesn't fade/yellow again, and then wetsands and polishes the UV finish so that the headlight looks brand new.
Old Feb 16, 2011 | 09:23 AM
Chebosto's Avatar
Chebosto
if you have a power drill handy, you can get the headlight refinishing kit @ Kragen or Pepboys for like $30. its a polishing ball with the Plasti-X type compound.
just hit the headlight for 15 minutes back n forth with the polishing ball and viola. done.
Old Feb 16, 2011 | 10:46 AM
Mextep's Avatar
Mextep
Don't forget to tape around the headlights..use auto paint tape..in case of any mishapp
Old Feb 16, 2011 | 11:24 AM
IDrm350's Avatar
IDrm350
The kits are very good. Especially the 3M kit. I would add one final step though. Using the sponge tool, polish with Meguiars Plastix. It gives a better polish on plastic than any other polish/rubbing compound I've tried (including what comes in the 3M kit which is pretty good).
Old Feb 16, 2011 | 11:25 AM
Chomorro's Avatar
Chomorro
I actually just bought this kit last week. One of my head lights are yellow so once it stops raining i will give it a go and post up results.
Old Feb 16, 2011 | 12:42 PM
SQBassHead's Avatar
SQBassHead
VolkZ seems to be the best, $25 and someone else does it post some before and after pics
Old Feb 16, 2011 | 04:13 PM
Chomorro's Avatar
Chomorro
Yea but riverside is an hour and half from me lol. I had it buffed by a body shop once for 30 bucks about a year ago but it didnt stay clear very long at all. Maybe 1 month tops.
Old Feb 16, 2011 | 04:42 PM
VolkZ's Avatar
VolkZ
the place i took it to was a glass and detailing place, you may be able to find some in your area.
Old Feb 17, 2011 | 03:18 PM
LaoSiFu's Avatar
LaoSiFu
Mucho gracias, I have always wonder about those kit. I am going to wait for the rain to stop so I can work on it
Old Feb 17, 2011 | 06:17 PM
r0me0ne's Avatar
r0me0ne
^^^ yep those work good. I dont think it last very long though so you may need to redo it like every 3 months or so. Mine will haze a little every once in a while. Just do the polishing with a drill then wax should look good afterwards
Old Feb 18, 2011 | 11:24 PM
Justin Yoo's Avatar
Justin Yoo
laosifu, did you have an ep before?
Old Feb 19, 2011 | 12:49 AM
scoobyrex247's Avatar
scoobyrex247
after you use one of those store bought kits you should take some sealant like:
Klasse All in Wonder grey bottle gloss. Follow that up with any high-quality wax.
Keep re-applying the sealant and after every wash.
here's mine after my first wet sand 1000 to 2000 grit wet sand. I also used a porter cable and rubbing compounds.
my z has never seen a garage. So after 6 years the sun has been brutal. Thank god for orbital / rotary buffers.
I should also say that after wet sanding the beam patter and overall light output has noticeably improved
Old Feb 19, 2011 | 01:12 AM
LaoSiFu's Avatar
LaoSiFu
What is an ep?
Nice sometime I wish I have a small buffer because I think I can work the hard to reach part much easier
