Greddy Type S coilovers
Old Jul 16, 2008 | 02:36 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Default Greddy Type S coilovers
I use these personally on my 07 Z... Great ride. Can be DUMPED, or ride at near stock height. They are the separate strut spring like the stock setup in the rear. 10k/8k spring rates. PM ME FOR BEST PRICING!!
Greddy Type S Coilover Kit Nissan 350Z Z33 03+
Designed for the optimum balance of traction, comfort, and adjustability, GReddy Type-S suspension kits offer the finest features like: large 46mm dia. pistons in a Mono-tube shock, 32 way adjustable damping, adjustable base and spring perches, thick billet upper mounts, and a lightweight coil springs. Instead of the common heavy spring rates, that offer harsh rides and easily loose traction on bumpy American roads, Type-S systems utilize a relatively softer spring with a longer stroke to maximize traction on the streets and track. An added benefit of this is also a comfortable ride for the street.
*Four Corner, Full Length Adjustable Ride Height:
With an adjustable threaded base and spring perch height adjustments can be made without sacrificing spring preload or shock stroke. Even with a lower ride height, by maintaining stroke, bottoming out can be prevented, thus maintaining traction even when hitting a dip while corning. In addition, by having both adjustments for the front and rear, it is possible to adjust ride height in millimeter increments if desired.
*32 way adjustable dampening:
By using a special 32 way valve needle, compression and rebound dampening can be simultaneously adjusted to suit both street and track use. The precise changes allow for sporty handling while still maintaining a comfortable ride.
*Adjustable Spherical Bearing Upper Mounts:
(pillow-ball) Standard equipment on vehicles equipped with front struts are adjustable spherical bearing upper mounts. The thick 10mm aluminum upper plates are precisely marked for secure and accurate camber adjustments. While the use of replaceable spherical bearings add extended life and cost effectiveness to the system.
*Mono Tube Shock Design:
The use of a large 46mm diameter piston in a Mono-tube shock design provides quick reacting dampening, even during low speed driving. While, the construction of the case is not only lightweight, but also designed to be very rigid.
*Strengthened Rubber Bushing Upper Mounts & Billet Aluminum Brackets:
For non-strut type applications, a thick 33mm strengthened rubber bushings on sturdy 10mm billet aluminum upper mount and lightweight billet aluminum brackets are used. This offers both exceptional noise reduction and very controllable handling profile.
* Lightweight High-grade Coil Springs:
All systems employ a special high strength steel (SAE9254) in it’s coil spring. This allows the springs to have the optimum balance of precise stroke, durability and lightweight. Rear springs are designed with 250mm (unless listed otherwise) variable springs to maximize the rebound stroke. This inhibits loosing traction when "lifting" while cornering. It also contributes to stable traction in wet or dry road conditions.
*Extended Adjustment Cable:
For applications with the rear shocks mounted beneath a rear deck lid (speaker board), an extended adjustment cable is included. This allows for easy dampening adjustments without having to remove components. All that is necessary, is creating a small 6.5mm hole for the tool.
Front: 10K-L200, Rear: 8K-L240
Old Jul 16, 2008 | 02:37 PM
Vivid Racing
Vivid Racing
Installed on my car. Right when I put them on, and the front was too low and the back was too high. haha
Old Jul 18, 2008 | 01:43 PM
Vivid Racing
Vivid Racing
PM's replied. Thanks guys!
Old Apr 21, 2010 | 09:06 PM
xcessiveskllzz's Avatar
xcessiveskllzz
is the bushing between the dampening setting and coilover available?
Old Apr 22, 2010 | 05:29 AM
stinky350z's Avatar
stinky350z
how expensive are these ? thanks hehe
sales@czp
Sep 23, 2019 03:30 PM
