Megan Racing Coilovers Street/Track!!
Old Jan 27, 2009 | 11:09 PM
mrwong@statik's Avatar
mrwong@statik
Vendor - Former Vendor
Default Megan Racing Coilovers Street/Track!!
Nissan 350Z
Model Number : MR-CDK-N3Z
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 10kg Front and 8kg Rear
- 32 Levels of Adjustable Damper
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
-Our Price..PM for Shipped Price
-For Either Track or Street Model
~PM for pick up price.~
Old Feb 4, 2009 | 02:38 PM
mrwong@statik
Old Feb 12, 2009 | 09:38 PM
mrwong@statik
pms replied.
Old Feb 13, 2009 | 03:12 AM
WV350z's Avatar
WV350z
price shipped 25311
Old Feb 17, 2009 | 06:15 PM
domepeace's Avatar
domepeace
how much shipped to 60123, can u also post when put 1-8 what kind of drop are we going to see?
Old Feb 17, 2009 | 06:19 PM
HeyItsDan's Avatar
HeyItsDan
how much shipped to 20841?
Old Feb 18, 2009 | 08:43 AM
homeboynyc's Avatar
homeboynyc
hey Mr.Wong how much for a set of track for me? greensboro 27406.
Old Feb 23, 2009 | 01:11 AM
mrwong@statik
pms replied..
Old Feb 25, 2009 | 12:56 AM
mrwong@statik
pms replied..
Old Feb 27, 2009 | 10:31 PM
mrwong@statik
pms replied..
Old Feb 27, 2009 | 11:05 PM
ramkat's Avatar
ramkat
shipped to 90703 or pick up thanks
Old Mar 1, 2009 | 02:27 PM
mrwong@statik
pms replied..
Old Mar 6, 2009 | 10:33 PM
mrwong@statik
pms replied..
Old Mar 7, 2009 | 10:57 PM
350XTCz's Avatar
350XTCz
Price shipped to 30097 please
Old Mar 8, 2009 | 10:10 PM
datsunHEAD's Avatar
datsunHEAD
shipped 93905 please
Old Mar 8, 2009 | 10:17 PM
QuicksilverZ33's Avatar
QuicksilverZ33
shipped to 10306 please
Old Mar 11, 2009 | 02:26 PM
rsoto20's Avatar
rsoto20
shipped to 79936
Old Mar 14, 2009 | 09:13 PM
mrwong@statik
pms replied...
Old Mar 18, 2009 | 12:49 AM
mrwong@statik
pms replied...
Old Mar 21, 2009 | 03:02 PM
WXSigns's Avatar
WXSigns
Track model to 98052, Thanks!
