SPC and Ichiba Camber Kits. BC BR Coilovers!!!
is this deal still available?
Hello Guys.
Got these in stock ready to ship.
SPC Camber Kit
After lowering the ride height of your 350Z. Excessive negative camber can actually hurt your traction, tire wear and cornering performance. The complete SPC Pro-Alignment front and rear camber w/rear toe kits replace the limited stock alignment adjustment and let you fine tune the handling and traction characteristics of your car. Now you can set up your ride for any driving scenario, from the street to the strip and anything in between. These kits will NOT fit cars with active steering
Application we stock.
03+350z
09+370Z
Front kit Adjustment range: Camber: -2.5 degrees to +2.5 degrees.
Rear kit Adjustment range: Camber ±4.00 degree Toe ±3.00 degree
BC BR Coilovers package's
Check website for special pricing:
http://www.b2autodesigns.com/product...roducts_id=715
Mono-tube shock design
30 levels of damping force
Pillowball mounts and adjustable camber plates included*
Adjustable rear camber plates available
Separate Full length height adjustable
Inverted and Non-Inverted setups
One year warranty
Rebuildable
Technical
Coilovers use 46mm pistons and 53mm shock housings.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating
Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
Iron lower brackets on MacPherson struts to ensure rigidity
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion
BR-Type:
BC BR coilovers with Swift spring upgrade.
Package BC Coilovers w/SPC Rear camber kit w/toe bolt shipped $1079.00
Please pm me with any questions you might have. Fast shipping as always
Thanks
Charles
SPC Camber Kit
03+350z
09+370Z
One year warranty
Rebuildable
Technical
BR-Type:
Thanks
Charles
