FS: SPEC-RS Coilovers 350Z/G35
Selling My SPEC-RS Coilovers only 300 miles on them. $1300 if i get full asking price ill pay shipping
here are the specs -Also including pics of my car to show you how low they go also in the pics the Coilovers are not maxed out
Features:
SPRING RATES:
F: 62mm ID; 200mm length; 12kg/mm
R: 62mm ID; 210mm length; 10kg/mm
DAMPER SPECS:
F: 125mm stroke; 220mm length
R: 125mm stroke; 220mm length
- Pillow Ball Upper Mounts
- External Reservoir for additional oil capacity and separate compression adjustment (New feature)
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Dual-Cylinder Design
- Steel front brackets/ Steel rear brackets
NOTE: Damper extension ***** are included for the rear coil-overs.
- All coil-over damper kits come with 1 year manufacturer-defect warranty.
- 32 Levels of Damper Force Adjustable; Separate Compression and Rebound adjustments.
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
Features:
SPRING RATES:
DAMPER SPECS:
- Rubber Dust Boots
Mom crashed her car so i gave her my car, and as you can see from the pics she in no way could drive the car that low. so i put it back too stock and i am selling my parts. and the coilovers are new 300 miles on them, the pic with them off the car is the condition they are in.
Its kinda hard for me to say, i didn't really have them long enough to break them in but the ride was really good for how low i was. and that was on stock setting i never messed with the adjustments. It was a smooth feel for how low i was.
