FS: NISMO T2 lowering / race springs
I'm selling the springs from my SCCA T2 car (I believe they are also discontinued). These are the NISMO T2 linear rate springs that afford a 1" drop all-around. They are not designed for OEM shocks, but I'll still sell them to you if you want them regardless.
I've seen the spring rates in LBS listed as both 690/690 as well as 600/690. I believe they are 690/690.
$350 plus actual shipping
I'm considering these... Can you find out what it would cost to ship them to 92154. Do you have any struts to go with them or can give me an idea of what struts i should get to pair up with the high spring rates? Thanks
Pending. . .
I'll let you know if the sale falls through, but I'm confident it's concrete. Thanks for your interest.
Anze Enginering Penske 8100 Series rebound adjustable shocks. $2100 the last time I called. These are valved for the T2 springs. You can add Penske canisters to them for double and I believe even triple adjustability. Had a deal for Ohlins not come my way, I would have bought these.
Bilstein HD shocks revalved by Bilstein $740 + $65 per to revalve = $1000
^Trust me, DO NOT use anyone other then Bilstein to do the revalve!!!
OTS Koni yellows revalved by Truechoice, PerformanceShock or Koni
$900 + $125 per =$1400 (OTS means Off The Shelf)
Tokico HP NO!
Tokico D-spec NO!
KYB GR-2 NO!
Any oem shock 2003 to 2008 NO!
raceboy
Feb 23, 2003 04:54 AM
