FS: Koni Double Adjustable aluminum bodied shocks
Old Nov 13, 2012 | 10:02 AM
Garak's Avatar
Garak
Default Koni Double Adjustable aluminum bodied shocks
These are custom Koni bump and rebound adjustable shocks. I have the shock dyno chart if you would like it. The rear shocks are adjustable from the bottom, and the fronts are adjustable from the top. Plenty of range for any track. Will sell with or without springs.
Front springs are 900, rear are 700.
Great condition.
Asking $2000 without springs. $2250 with springs.
PM me if interested.
http://www.flickr.com/photos/79943613@N07/8182877352/
http://www.flickr.com/photos/79943613@N07/8182877894/
Old Nov 28, 2012 | 03:09 PM
plastidipping's Avatar
plastidipping
how much for the springs? pm me if interested,good luck either way
Old Nov 28, 2012 | 05:11 PM
jarrodh77's Avatar
jarrodh77
Bump for legit shocks. I'd be all over these if I wasn't selling the car.
Are top mounts included for the front? Upper/lower mounts for the rear springs?
Old Nov 28, 2012 | 09:22 PM
Frostydc4's Avatar
Frostydc4
How many miles are on the setup?
Old Nov 29, 2012 | 08:27 AM
Garak's Avatar
Garak
There are about 500 to 750 miles on each set of shocks. Not much at all. If you need the revalved, any reliable race shop can do it, but you're not going to need them revalved for a while. And I can supply the shock dyno chart with each set so they can be brought back to the exact setup if they ever did start to fade.
Mounts are not included, as they are direct replacement for the OEM shocks.
Old Nov 29, 2012 | 08:44 AM
03threefiftyz's Avatar
03threefiftyz
2812's are nice shocks, and this is a good deal for someone out there...
Old Nov 29, 2012 | 10:54 AM
SE5spd's Avatar
SE5spd
Waitwut?
You never see nice suspension in the FS section.
GLWS OP!
Old Dec 11, 2012 | 08:49 AM
Garak's Avatar
Garak
Thanks guys. You're right. The quality on these shocks is unmatched. Made in the USA and are super reliable.
Anyone who gets these will be really happy with them.
Old Dec 11, 2012 | 05:27 PM
INTIMAZY's Avatar
INTIMAZY
The most important question you didn't address is whether or not these shocks can let you slam your ride lower than Ksports or BC.
Oh they can't?
These must be junk then...
Hope the sarcasm wasn't lost on ya. If I had that kind of cash right now I would be all over these especially since you're local. What kind of racing do you do?
Old Dec 28, 2012 | 08:59 AM
Garak's Avatar
Garak
Oh, I got the sarcasm! ;-)
If your interest is in slamming the car, these are not the shocks for you.
However, if you want the car to handle like it's on rails, then yes, these are the best things this side of $5,000 triple adjustable Motons.
I'm open to resonable offers. I'd like to get them out of the garage.
Old Dec 29, 2012 | 01:01 PM
03threefiftyz
Sadly, double motons cost $5,000....triples are closer to 7000-7500.
Old Jan 1, 2013 | 11:54 AM
terrasmak's Avatar
I know someone who may be interested. He would only need the 700 pound springs. Also how hard is it to convert these to true coilover?
Old Jan 8, 2013 | 01:25 PM
Garak's Avatar
Garak
You can put 700 lbs springs on and these shocks will be fine. They had adjustable spring perches and the compression and rebound are adjustable, so they can be dialed in to what ever spring rate you want to try.
Old Jan 8, 2013 | 01:30 PM
Garak's Avatar
Garak
Also, the front is essentially a 'coil over.' The rear of the 350Z doesn't lend itself to having a coilover as the top of the rear shock mount area wasn't designed to hold the weight of the car; nor the lower control arm for that matter. (Not passing judgement on any system that would use this, just that Nissan designed the frame to be the load bearing part of the rear suspension). Most Pro developed 350Zs I've seen all used the stock spring perches...
Old Jan 8, 2013 | 06:58 PM
ian99rt's Avatar
ian99rt
I must resist no matter how much i want to buy these. House needs a new pool.
Damn responsibilities
Old Jan 11, 2013 | 09:55 AM
Garak's Avatar
Garak
Ian, put the pool on the VISA! Your 350Z REALLY REALLY needs these!! Besides, they're a fraction of the cost of a pool and you'll use the shocks everyday! ;-)
Old Jan 16, 2013 | 01:28 PM
soifigured's Avatar
soifigured
Sent you a PM about the shocks.
Old Feb 26, 2013 | 02:18 PM
Garak's Avatar
Garak
Still have these available!
Old Mar 4, 2013 | 12:19 PM
ian99rt's Avatar
ian99rt
PM sent with offer
Old Mar 4, 2013 | 06:19 PM
ducky's Avatar
ducky
so tempted to get these...if ian99rt doesnt get these I may throw an offer your way as well...
