FS: JIC Magic FLT-A2 Coilovers
Old May 2, 2013 | 10:29 AM
CH@Dbee's Avatar
CH@Dbee
Default JIC Magic FLT-A2 Coilovers
I'm selling my JIC Magic FLT-A2 coilovers. They have about 8k miles on them and are fully functional with minor cosmetic blemishes as to be expected with a pre-used set of coilovers. The area where you tighten the collar is damaged on the rears but it has zero effect on the way the suspension rides, performs or the functionality of ride height adjustment. This is a high end suspension system that costs $2100 new and are very rare these days.
SOLD SOLD SOLD SOLD
FLT-A2 Series suspension kits are JIC Magic's flagship coilover setup! The FLT-A2 features lightweight, 15-way adjustable inverted monotube 40/45mm piston dampers that ensure high strength and fade free performance. The ride height is adjustable, separate from the spring perch giving maximum suspension travel at any setting. This also allows for proper corner weighting of the vehicle without effecting spring preload settings. Also features linear springs that give laser precision steering response in all kinds of harsh road conditions.
Coilover kits from JIC include upper pillow ball mounts for improved chassis stiffness and better handling while the MacPherson strut design helps benefit front camber adjustability providing built-in caster/camber adjustment. The multi-link suspension design features CNC machined aluminum lower brackets or high tensile steel brackets depending on the application.
15-Way Adjustable Dampening. Inverted Monotube 40-45mm Piston Dampers. Anodized Aircraft Aluminum Pillow Ball Upper Mount. Adjustable Height from ½ to 3-inch Drop. Duralumin 6061 Lower Seat. Cool-Bend Chrome Silicon Metal Linear Rate Springs. Rubber Bump Stops Prevents Bottoming Out. Aircraft Aluminum/Hard Steel Brackets.
$1050 + shipping
Old May 5, 2013 | 05:27 PM
CH@Dbee's Avatar
CH@Dbee
I'm open to offers that are reasonable.
Old May 7, 2013 | 10:43 AM
CH@Dbee's Avatar
CH@Dbee
New price! $900 firm + shipping/pp fee
Old May 7, 2013 | 11:22 AM
pgZETO's Avatar
pgZETO
Pm sent
Old May 7, 2013 | 11:26 AM
pgZETO's Avatar
pgZETO
Nvm sorry free bumps though!
Stevo Z
Oct 3, 2015 09:14 PM
