Need Help w/ throttle
Old May 6, 2008 | 05:04 PM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
Default Need Help w/ throttle
Hey guys, please give me something to tell the stealership to go out and check. I have a 5 speed AT that is acting weird.
I know we have drive by wire & no cable, So what could be causing my sparratic & interupting & hessitation of acceleration ??? We have alot of different sensors that could effect the throttle body....so what else can be doing this ?
The stealership says that I'm not producing a check engine light....so there is no code to be checked.....so they don't know where to look.
Besides the spontaneous hessitation of acceleration in every gear at usually above the 3000 rpm mark, the car runs and sounds fine. It also will and has stalled at a stop light many times.
Anyone with something to help out, please post.
Thanks
Old May 6, 2008 | 05:10 PM
j.arnaldo's Avatar
j.arnaldo
1. Throttle body sensor? 2. EGR valve? 3. Throttle body clean up? 4. MAS ("MAF sensor", as they call it in these threads) clean up? I don't think the car
having an AT has anything to do with it. Good luck!
Old May 6, 2008 | 06:13 PM
bommart's Avatar
bommart
fuel injects/fuel lines maybe?! im just taking a guess...
Old May 6, 2008 | 06:17 PM
LegionnaireZ's Avatar
LegionnaireZ
one of the above sounds like a great place to start off...
another couple of things i would check...
fuel filter (might prove more difficult than it sounds...Never done it on our cars personally... but if clogged can cause hesitation by starving it)
fuel quality... walmart gas FTL...
plugs
O2 sensor
or some random a$$ vacuum tube somewhere sucking air...
maybe some of the more tech savvy guys can come in here and elaborate on the lists mentioned... and give their ideas and advise...
Old May 6, 2008 | 06:30 PM
CSF's Avatar
CSF
regarding your stalling at stops...possibly an idle control problem?
does your car idle ok?
also, do you have any mods? how many miles do you have? how old are your plugs?
Old May 6, 2008 | 07:55 PM
LegionnaireZ
Fithamoto... you should try to come to the G/Z meet in arlington this upcoming 10th... at 10am... supposedly there's a guy bringing a cipher tool... and from what i read in the meet thread it should be able to identify problems similar to what you have... check out the thread and see what ya think!
Old May 7, 2008 | 12:21 PM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
I'm already signed up for the meet. I would like to see if he can find anything out with the Cipher tool. How much does he charge ? I hope I can drive my Z out that far.
j.arnaldo --- thanks for the leads. I'm having Nissan look at the MAF and fuel lines & filter.
CSF --- Plugs are most likely original, I have 38,000 miles, & simple Mods ( Nismo CAI, Nismo exhaust, & 5/16th Plenum spacer. ) The Idle acts up whenever the throttle is skipping.
Boommart --- They tell me that the fuel injectors have more than enough pressure & should hardly never get clogged. We'll see....if they can find out whats doing this.
Thanks to all for giving me something to go on. I'm expecting Nissan to call me up this afternoon with a diagnosis.
If you think of anything else then let me know. Thanks Peeps
Old May 7, 2008 | 01:14 PM
nismospec's Avatar
nismospec
let me know what Nissan finds out. I'm having similar issues w/ my car. Same mileage, but I have an 06' m/t. Acceleration seems sluggish, and at high speeds, stomping on the throttle causes a choking symptom.
Old May 7, 2008 | 10:47 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I'd suspect the TB before anything else. BTW, if the dealership couldn't find any codes (which will show on your dash anyway using lights), cipher wouldn't magically find a code.
Keep us updated.
Old May 7, 2008 | 11:25 PM
LegionnaireZ
noticed that after i posted... great hopefully he finds something... and i don't think he'll charge but i'm not sure... Moog said he's bringing it so ppl can check it out.. so i'd think he's bringing it to toy around with it... and it'd be interesting to run it on a car that actually HAS a problem...
See you there...
Old May 8, 2008 | 11:13 AM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
Keep us updated.
Well got the Z back from Nissan late Yesterday. Seems that they replaced the MAF sensor and that did the trick. They couldn't tell me or explain why it was doing that, but they seem to be very sure that it shouldn't act up again.
I drove the Z out of the dealership and noticed an immediate difference in acceleration & even exhuast sound. To me it sounded much purer & tighter, not as loose. I did start to notice just a little bit of an gurguling sound in the exhaust. As if the mixture was a little rich. Also my tail pipes had much more residue on the bottom of the pipes.
So in a short I guess it was only the sensor causing this hesitation of fuel mixture and cutting it off sparratically.
So "nismospec" if your having these same symtoms I would have the MAF sensor checked out. Mine got worst thru-out the work week. Then I just couldn't stand it anymore.
Good luck !
foot note* Btw I lucked out in timing, because I just decided to go ahead and pay for this extra extended full coverage warranty with no deductibles. Woot !
The dealearship's invoice was $ 414.00 for the part & labor. Not a ton of money but still no cash out of my pocket. So the warranty will be a nice peice of mind.
Old May 8, 2008 | 11:43 AM
nismospec's Avatar
nismospec
thanks for the info, i'll check it out. And +1 for the extended warranty. I got a heck of a deal on mine since the dealer quoted me on a Sentra instead of a Z. I love stupid people
Old May 8, 2008 | 02:30 PM
3hree5ive0ero
Retired Admin
That awesome to hear. BTW, reset your ECU (just in case the dealership didn't). That way, it'll relearn with the properly functioning MAF sensor and get your maps straight.
Old May 8, 2008 | 02:45 PM
CSF's Avatar
CSF
good to hear...coincidentally, a co-worker is having similar problems. not a Z...but I'll tell them to check that out
Old May 11, 2008 | 04:39 PM
wnt1bd's Avatar
wnt1bd
I used to work for a stealership and we would see this on occasion.....to me it sounds like either the maf sensor or the tps (throttle position sensor) we had a few tps's go out and that would cause stalling sluggish starts and failure to reach full throttle on some occasions. Alot of the time its when someone is installing a spacer and disconnects or reconects the tps while that battery is pluged in. Thats my two cents.......good luck
Old May 11, 2008 | 04:57 PM
jmccartney's Avatar
jmccartney
I'm subscribing becuase im having the same issue. If I stomp on the gas it seems like it bogs out and hestitates over 3,000 rpm. It is spuratic though, sometime power kicks in then out at high rpms. Is there a MAF cleaner I could try? I would hate to have to buy a new sensor
Old May 11, 2008 | 06:56 PM
CSF's Avatar
CSF
might as well try it...isn't a maf sensor like $200?
Old May 12, 2008 | 03:37 AM
jmccartney's Avatar
jmccartney
well im going to use maf cleaner and see if that works. if not then i will get a new one. I priced them and they are $75. Now if I go to the stealership that would be a different story
Old May 12, 2008 | 04:50 AM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
Thanks Chris,
What would this consist of ? I have heard of people doing or trying this.
Do you disconnect the battery terminals or something like that? I might need a talk thru .
Also jmccartney,
I would go ahead and clean it.....but be gentle. maybe an air hose with some kind of degresser. Not too sure. But it sounds like you have a parts connection.
Good luck & keep everyone else up to date since it sounds like there might a few others with this same problem.
Old May 12, 2008 | 08:41 AM
3hree5ive0ero
Retired Admin
http://www.technosquareinc.com/350reset.htm
Disconnecting the battery doesn't do anything.
