[DFW]: Help! Freon leak
Old Jul 12, 2009 | 10:56 PM
Doh-Joe's Avatar
Doh-Joe
Default Help! Freon leak
I have a '05 Z equipped with popcharger (had it for long time now w/no prob). During the weekend I took the filter out to have it clean. When I put it back, turns out I didn't position it properly causing back part of the filter to rub on the freon line. Yes, their was a leak but fortunately I was able to catch this soon & reposition it correctly. You can't see the hole w/your naked eyes but their is a very tiny tiny hole. Best case scenario I'm thinking/hoping this can be welded. Worst case, I need to replace the whole line which I'm assuming it's labor intensive. Anyone recommend a trust worthy shop that can fix this?
Old Jul 13, 2009 | 05:36 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Don't know about the line or a shop, but did you oil your filter after you cleaned it?
Old Jul 13, 2009 | 06:43 PM
Doh-Joe's Avatar
Doh-Joe
No, I swapped out the filter to AEM dry flow air filter.
Old Jul 13, 2009 | 08:06 PM
son_jaoku's Avatar
son_jaoku
You have to replace it and I would just take it to the dealer if it was me. If you don’t want to go that route you should take it to a shop that has an A/C machine. More like this one http://www.denlorstools.com/shop/ima...AC_Machine.jpg because those machines will not recovery contaminated R-134a. Also, since there is a leak there is moisture in the system and that machine will vacuum it all out.
Old Jul 13, 2009 | 08:16 PM
Doh-Joe's Avatar
Doh-Joe
*sigh* I think I'm just going to have to start calling dealerships tomorrow. I didn't really get a chance to look around for a reputable shop but driving around in Dallas w/o A/C can be a real b!tch. Thanks jaoku!
Old Jul 13, 2009 | 09:35 PM
Gibbs's Avatar
Gibbs
Know it all
Use some JB weld!! I love that sh*t.
Old Jul 13, 2009 | 10:39 PM
Doh-Joe's Avatar
Doh-Joe
I just googled JB weld & it actually seems promising. Sucks I still have to get my A/C refilled though.
Old Jul 13, 2009 | 10:46 PM
quakerroatmeal's Avatar
quakerroatmeal
Check online at courtesy parts to see how much the hard line is.. Try to look at the route to see bad it is. I wouldn't think it'd be that bad to replace. JB weld would work too.
Old Jul 13, 2009 | 11:07 PM
Doh-Joe's Avatar
Doh-Joe
Couldn't find it.
I followed the line and it leads to where our brake fluid container is and continues on towards center of the car. If I replace the entire line I fear this will be very labor intensive.
Old Jul 13, 2009 | 11:40 PM
SpeedRcr's Avatar
SpeedRcr
When you put in the pop charger you should bend the ac line to move it and cover it with insulation foam wrap
Old Jul 14, 2009 | 04:50 AM
huyrua's Avatar
huyrua
I had the same problem. My K&N intake box rubbed at the same area. I ordered the parts from the dealership. Can't remeber the price but I think it was around $70. The line was fairly easy to installed. Then I bought the recharge kit and added the freon myself. Total cost was around $150.
Old Jul 14, 2009 | 06:07 AM
Kristi's Avatar
Kristi
I am Awesome
Whats up fool - I saw you up at Jotech the day you found out about the problem
sorry to hear about it
Old Jul 14, 2009 | 02:48 PM
Doh-Joe's Avatar
Doh-Joe
Sucks. Kind of glad I'm not the only one with this issue.
Old Jul 14, 2009 | 03:10 PM
Doh-Joe's Avatar
Doh-Joe
Oh hey! Yeah I remember you asked me what year my car was right? Nice to meet you. Sorry if I didn't seem talkative or friendly. I was just a little PO at the time when I found out about my car.
Old Jul 14, 2009 | 05:33 PM
son_jaoku's Avatar
son_jaoku
You can either put a bandage on it and hope it doesn't fail later on or get it done right. I would suggest you replace the line yourself and take it to a shop with an A/C machine. Again, there is a leak so there is moisture and maybe dirt in the system (A/C is a sealed system), if not taken care of it may ruin the compressor later on.
Old Jul 14, 2009 | 06:52 PM
Kristi's Avatar
Kristi
I am Awesome
Don't worry I understand - After seeing your car I went to check mine to make sure my pop charger hasnt caused the same thing
IDK how that would have happened... its odd
Old Jul 14, 2009 | 07:54 PM
Doh-Joe's Avatar
Doh-Joe
You and me both...
I was actually considering what others have said above and just seal it up with JB weld but I think you actually have a good point. I'd rather pay extra and get it right the first time. I would totally do it myself but I couldn't tell you single thing about car A/C if my life depended on it. So I guess it's off to the dealership...
Old Mar 10, 2011 | 10:44 AM
Doh-Joe's Avatar
Doh-Joe
Going over my past created threads. If anyone cares about the outcome I actually took my car to a dealership that my friend happened to be working and got free refill on freon after I used the JB weld to cover up the leak. Have not had a issue since.
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
