Help with tire size..
Old Oct 26, 2009 | 04:00 PM
ricerocketdave's Avatar
ricerocketdave
Default Help with tire size..
We need tires for the Z..
It has Rota P45R 18x9.5 on all four corners
I have no idea what size tire to purchase for the rims. I really need some help with this one.
Thanks everyone!
Old Oct 26, 2009 | 04:38 PM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
What size is on there now ?
Old Oct 26, 2009 | 04:43 PM
ni$mo350's Avatar
ni$mo350
You can run a safe f-255/35 r-275/35 setup. Seems like the most common setup...
Old Oct 26, 2009 | 04:53 PM
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
I've got the same wheels. I'm assuming you're running the +20 offsets and not the +30. The +20 is standard with those wheels.
Anyway, I've got Kumho ASX (all season) tires on there:
Front = 255/35/18
Rear = 275/35/18
Now that's with the Eibach Pro Kit drop and there's still a bit of a gap (1" drop).
If you are running on stock suspension I would recommend these tire sizes:
Front = 245/40/18
Rear = 275/40/18
If you search through the Tech Forums/Wheel and Tire then you'll find alot of info.
Old Oct 27, 2009 | 06:39 AM
phiooz's Avatar
phiooz
i was running 245 40 18 fronts and 275 40 18 in rear
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
