Utec Problem - Cel
Old May 1, 2006 | 09:26 AM
IIQuickSilverII's Avatar
IIQuickSilverII
Default Utec Problem - Cel
I just got my UTEC tuned this weekend, and i got a 13whp gain. but i have a CEL that is just constantly on(rigth from when i start the car)
so:
- have any of you guys had this problem before?
- should i reset the ecu? how do i do it?
- will resetting the ecu make me loose the map on the utec?
some n00be questions here, hope you guys can help me.
Old May 1, 2006 | 10:53 AM
arizzee's Avatar
arizzee
A scan tool will read and clear the code, but will it come back if condition still exists. I'd go this route to see what the problem is. autozone should be able to read and clear for you.
to reset ecu, go to technosquares website; they have the procedure posted. this will not clear your utec map (which you have saved, right?)
btw, who did your tuning?
Old May 1, 2006 | 10:54 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Technosquare website has the procedures for checking CEL's and getting the cods via blinking dash light using the throttle procedure, its easy to do just have to time everything right or use a code reader to see what the specific code is, we cant really tell you if its normal unless we know the code. The resetting of the code/ecu will not clear any of your UTEC maps.
Old May 1, 2006 | 11:05 AM
Kiamo's Avatar
Kiamo
There are two switches on the UTEC under the TurboXS logo. If they are in the wrong place, it will cause a CEL. They should both be down towards the harness port IIRC (check manual to be sure).
Just an idea...
Old May 1, 2006 | 11:18 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
did you add test pipes along with it by any chance??
try to get a scanner and figure out what code it is when you get a chance..
Old May 1, 2006 | 11:54 AM
IIQuickSilverII
"There are two switches on the UTEC under the TurboXS logo. If they are in the wrong place, it will cause a CEL. They should both be down towards the harness port IIRC (check manual to be sure).
Just an idea..."
This seems to be my first test to check what the problem is...
So they should both be pointing down towards the ports huh
THe CEL light was inmediate so i am pretty sure its not related to a particular problem other than somethign with the utec.
Anymore comments are welcomed... Thanks
Old May 1, 2006 | 11:58 AM
Kiamo's Avatar
Kiamo
Just an idea..."
I just checked the manual, and both switches should be "down" towards the harness connector (up being towards the logo). Its on the manual on page 54 (manual is on their site if you don't have it). The light will need to be cleared if you change the switches; just use the method on Technosquare's page.
Old May 1, 2006 | 01:24 PM
Julian@MRC's Avatar
Julian@MRC
DO you have test pipes/high flow cats?
Old May 1, 2006 | 01:25 PM
IIQuickSilverII
I have test pipes, but i had them on for a while now...and i didnt' get a CEL
i have an 03 performance model
is it possible that because i now have new settings because of the tuen it would come on?
Old May 1, 2006 | 01:48 PM
Julian@MRC's Avatar
Julian@MRC
Could be, but without having the actual trouble code ffrom the ECU there is no point in speculating anything at this point.There is no way to diagnose the problem without first knowing the codes on the car..
Old May 1, 2006 | 01:50 PM
IIQuickSilverII
yah.. ill try to get this as soon as possible... Do you ahve aan email or somethign i can contact you other than here?...maybe i can text you and you can help me..if possible...
Old May 1, 2006 | 02:00 PM
IIQuickSilverII
what is the CEL code for the trouble you get with the TESTPIPES anyways?
or if it is what KIAMO mentiones...what is the code...
Old May 1, 2006 | 02:09 PM
cox's Avatar
cox
Old May 1, 2006 | 06:43 PM
Nathan's Avatar
Nathan
Quksilver
Crank over the motor to start it & check the voltage on the volt meter.
If it drops below 9 volts on cranking you will get a CEL 0150 (ignition circuit)
The UTEC's power supply is from the factory ECU & if your battery is low the combined current draw of both units on cranking will trigger a CEL.
To check, use a battery pack or jump start leads to start & see if that fixes the problem.
Old May 8, 2006 | 12:11 PM
IIQuickSilverII
AND THE WINNER IS.............. KIAMO
you got it..that was the problem. cleared the CEL and car is running great. THank you everybody for your imput
Old May 9, 2006 | 12:45 PM
Road Warrior's Avatar
Road Warrior
can you clear a CEL with the utec or do you have to have a obd2 tool?
glad to hear you got the problem resolved quicksilver
Old May 9, 2006 | 12:47 PM
Cannysage's Avatar
Cannysage
how much for the tune?
Old May 9, 2006 | 03:26 PM
EM-EFER's Avatar
EM-EFER
+1... someone please respond
Old May 9, 2006 | 03:33 PM
mario60185's Avatar
mario60185
Chicago Realtor
What mods do you have on your car?
Old May 20, 2006 | 06:19 AM
IIQuickSilverII
i used techno square method to reset the ecu. this does not affect the utec
tune was 350. main goal was gain a bit more power than the provided map and secure a/f ratio.
mods i ave are:
injen cai
injen ses
ur crank p.
res test pipes
md 5/16 spacer
b&m shifter
