UTEC rev limiter
Old Jul 26, 2006 | 01:33 PM
Kiamo's Avatar
Kiamo
Default UTEC rev limiter
I have my rev limiter set to 72 in the UTEC, but it still kicks in at around the same point as stock. I tried 75 as well and got the same result. I am using open loop fueling (its set to 1) on version 2.6. My TPS threshhold is 75, RPM threshhold is 20. Any ideas?
Also, why is the stock injector size in the UTEC 380cc? I thought the Z had 290cc injectors...
Old Jul 26, 2006 | 02:16 PM
techcontrol's Avatar
techcontrol
If you own an 2005 or 2006 Z then good luck with adjusting the rev-limit with the UTEC because it can't be done yet. You'll need to get the ECU reflashed to accomplish this.
Old Jul 27, 2006 | 12:53 AM
mistaboosta's Avatar
mistaboosta
2004 > can't raise idle
2005> can't raise idle and rev limit
2007 > can't open hood
Old Jul 27, 2006 | 02:43 AM
mchapman's Avatar
mchapman
I would recommend experimenting with lower than stock rev limits first until you get it working correctly. You can go down to 5000rpm.
Did you turn the car off and then on again after saving the settings?
Old Jul 27, 2006 | 07:50 AM
first350's Avatar
first350
https://my350z.com/forum/tuning/205297-what-size-is-the-stock-fuel-injector.html
the thread says our injectors are rated at 290cc, but since our fuel system is returnless, we run slightly higher fuel pressures than what is used to calculate injector sizes, which cause our effective injector sizes to increase (higher pressure means more fuel)
Old Jul 27, 2006 | 12:34 PM
Kiamo's Avatar
Kiamo
I have a 2005. Well crap.
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
