TXS Tuner Pro Headphones not working
Old Aug 1, 2006 | 11:51 PM
mistaboosta's Avatar
mistaboosta
Default TXS Tuner Pro Headphones not working
Hi,
I've plugged in a pair of headphones to my Tuner PRO yesterday for the first time to listen for knock but found out that no sound is coming from the headphones. Is there something that i have to calibrate or something before being able to hear something? Or is the problem within the unit itself? Checked for the installation and everything looks fine. The knock sensor is located ON the stock knock sensor.
Old Aug 2, 2006 | 12:17 AM
mchapman's Avatar
mchapman
Can you clarify where the knock sensor is located?
Is the knock sensor mounted on the metal block itself?
Did you try turning up the volumne?
Old Aug 2, 2006 | 03:16 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
knock sensor is located on the top of the block, under the lower runners that are under the plenum. it is right between the heads....
mista, i dont remember anything about calibration with the headphones but havent used them yet...
Old Aug 2, 2006 | 06:24 AM
BlackTuner's Avatar
BlackTuner
The headphone output should work without any problems. It does not have an off button or a calibration. While it does have a volume **** even at it's lowest point you should hear something.
Try, turning the **** completely to the right. Also make sure your knock sensor cable is connected.
Thanks,
Jermaine~
Old Aug 2, 2006 | 03:04 PM
mchapman's Avatar
mchapman
I meant where has Mistaboosta mounted it, has he physically mounted it on the metal part of the block near the factory knock sensor or on top of the stock knock sensor? Just clarifying his choice of words.
Old Aug 2, 2006 | 04:08 PM
mistaboosta
The knock sensor of the TUNER is located righ ON the stock one. Stock one has contact with the block itself and the one I've installed on it has metal surface contact with the stock one.
I've already tried the **** but there is no noise coming. Interestingly, when I turn the **** fully right or fully left, the Tuner stops showing the AFR LOL
do you think something is wrong with the unit Jermaine?
KOF
Tuning
Sep 30, 2015 04:09 AM
35reilly
Sep 28, 2015 07:42 AM
