Raytec users?
Old Aug 17, 2006 | 02:45 PM
PL510_Z33's Avatar
PL510_Z33
Default Raytec users?
Hey everyone...just seeing if anyone has used Tomei Raytec before. Might be a little daunting using a rarely used stand alone instead of say, AEM or Electromotive but I want to use Raytec since I trust Tomei products and they provide base maps available online for the exact engine spec I intend to eventually run once I build up a short block.
The chassis will be my trusty 1971 Datsun 510 with a 4:38 F/D ratio. The engine to replace my lazy but loved KA24DE will be a N/A SR20 using SR20DET ignition with individual coil packs. I plan on basic cams and springs untill I build a 2.2 bottom end. The Raytec is to run Tomei's 4 throttle intake (individual throttle bodies) and eliminate having to send out my ECU everytime I step up cams, increase displacement, bla bla. And the ITB's won't use a mass airflow sensor of course. I know it'll be a bit hairy getting fuel and ignition curves right, but it WON'T be a driver...that's what the 350Z's for!!
Thanks.
j!
350Z_Al
Oct 29, 2020 07:44 PM
