EU problems on a REVUP
Old Aug 23, 2006 | 08:10 PM
97supratt's Avatar
97supratt
Default EU problems on a REVUP
Hey guys,
I bought a EU system with the autosport harness from a member here on the board. the wiring was done by Sharif and I must say it looks very good.
I installed it and ran the datalog and honestly it sucks. For some reason it retards timing a lot, and I can't get it to work correctly. My car feels very slow.
Any advice?
Is the wiring the same on the 03-05 as the 06 revup?
Old Aug 24, 2006 | 08:16 AM
97supratt's Avatar
97supratt
Anybody?
Old Aug 24, 2006 | 11:34 AM
BlackZero6's Avatar
BlackZero6
Im not sure but i thought the only changes to the revup were on the exhaust cams and a lower plenum...i dont see why wiring would change
Old Aug 24, 2006 | 11:36 AM
97supratt's Avatar
97supratt
Anybody feel like playing around with the EU and tuning it? I'll get some beer to help out.
Old Aug 24, 2006 | 12:52 PM
FairLadeeeZ's Avatar
FairLadeeeZ
Just sell me your EU and get a UTEC
Old Aug 24, 2006 | 01:03 PM
97supratt's Avatar
97supratt
What sorta price are you proposing? It needs to be worth it for me.
Old Aug 24, 2006 | 01:37 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
pm sent
Old Aug 24, 2006 | 02:04 PM
97supratt's Avatar
97supratt
Originally Posted by Wired 24/7
pm sent
Replied to.
Old Aug 24, 2006 | 02:19 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The items that are wired on the EU, should be the same on the rev up motor. Injectors, ignition, etc..etc..
Maybe the parameter settings or the tune is not setup properly? How badly does it run?
Old Aug 24, 2006 | 02:50 PM
97supratt's Avatar
97supratt
Well at first I had big drops in engine rpm, timing, & airflow on the data logger after 6k rpm. It felt very sluggish, and I didnt know what type of knock control to use.
Everything was at 0 but I felt it pull timing with the stock map. Would you happen to have a base map I can run N/A? How about the parameter settings? What are they supposed to be exactly? I entered the engine code and left them at that. I didn't change anything.
Plus I heard slight pinging at some moments. It ony happened when my foot was off the accelerator and then I pressed the gas pedal down 10%. It was definitely pinging with the EU on there, when I took the EU off, it didnt ping.
Old Aug 24, 2006 | 04:09 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Speaking of parameters...
Sharif, do you know what parameter or setting to use for "sensor type" under air intake temp sensor and coolant temp sensor?
I searched the forums and I'm 99% sure it hasn't been posted.
Old Aug 24, 2006 | 05:35 PM
Sharif@Forged
Forged Performance
wired: Sensor type for intake is Nissan, and same thing for coolant temp. I think they abbreviate it to Nis or something very easy.
Supra, those drops in RPM and usually some noise. I have seen that a few times before on the 350Z, and was never able to determine what it was. It doesnt appear as power loss on the dyno.
Old Aug 24, 2006 | 06:20 PM
fito's Avatar
fito
have it tuned, I have had a few cars that even having the EU on 0 it changes something.
Old Aug 24, 2006 | 10:09 PM
97supratt's Avatar
97supratt
Hey sharif can you PM me or post the parameters we need for the 350z? Maybe I had them wrong.
Old Aug 25, 2006 | 05:51 AM
fito's Avatar
fito
There is nothing special on the parameters, just choose VQ35de, nis intake sensor, nis water sensor and change the units to psi.
Where is your timming running in the logger?
Old Aug 25, 2006 | 07:12 AM
97supratt's Avatar
97supratt
I took it off, so I dont remember any of it.
Old Aug 25, 2006 | 07:14 AM
97supratt's Avatar
97supratt
What kind of air/flow device do we have hotwire?
Old Aug 25, 2006 | 11:52 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
99% sure it's hotwire yeah
Old Aug 25, 2006 | 12:23 PM
97supratt's Avatar
97supratt
Hey Mike,
Are you gonna join us at the Burbank/Glendale meet? I can bring my e-manage ultimate as well if you show up.
Arin
Old Aug 25, 2006 | 06:11 PM
fito's Avatar
fito
it's a shame, because you are taking out a really good system, just out-marketed by others.
