UpRev ECU Flash: Multiple maps on stock ecu
Old Nov 17, 2006 | 06:37 AM
dTor's Avatar
dTor
Originally Posted by UpRev
Just switch to the next Map and count the "set" lamp flashes to see where you are at. There is no waiting time between the switches, so this can be done in seconds.
Can the maps be changed on the fly (i.e., car in motion) or must you reduce your speed or stop the car (I know you said you don't have to shut it off)?
Old Nov 17, 2006 | 06:56 AM
Old School's Avatar
Old School
Shift_Boost
The UTEC can switch on the fly, but you must drop the Rs below 1600rpms if I'm not mistaken. Might be the same situation here...if not, that's cool.
Old Nov 17, 2006 | 02:11 PM
UpRev's Avatar
UpRev
On-the-fly map switching is possible (while the vehcile is in motion). However, we recommend the vehicle be stop for general safety reasons.
Old Nov 17, 2006 | 02:25 PM
rocks's Avatar
rocks
Can you advance and retard cam timing with the reflash?
Old Nov 17, 2006 | 02:59 PM
znot's Avatar
znot
let's say i don't want valet guy to be boosting around the corner and out of sight, is that possible even if ecu is already flashed by tn for their st setup? ie....me driving=can boost.......other people driving=cannot boost....thanks.
Old Nov 17, 2006 | 09:22 PM
rocks's Avatar
rocks
znot they can put 3 maps in it so yes. they use the same software as turbonetics....
Old Nov 18, 2006 | 08:42 AM
dovla's Avatar
dovla
I doubt that UpRev is using same Techtom software (or any Techtom product) as TS.
Old Nov 18, 2006 | 09:09 AM
Nismo350ZRT's Avatar
Nismo350ZRT
This reminds me of the APR flash on Audis. Same deal...multiple maps and switching with the cruise control buttons.
Old Nov 20, 2006 | 08:39 AM
znot's Avatar
znot
if either company's software can accomplish the same task at hand at customizing the 3map settings, would it then come down to price ?
not sure if Turbonetics can do the custome 3 map setting though.
Old Nov 20, 2006 | 09:06 AM
02toyowrx's Avatar
02toyowrx
As far as I am concerned Cobb Tuning for the win, they are expected to release the accessport for the Z and nissan models soon. Their unit is supposed to be similar to what they offer for the Subaru models, and from past experience they offer a top notch product.
No more downtime with mail in flashes for me.
Old Dec 24, 2006 | 04:25 PM
doug's Avatar
doug
you realize no one asked you that?
Old Dec 25, 2006 | 12:24 PM
chenzo425's Avatar
chenzo425
Smile uprev reflash
how much horsepower gains should i expect? thanks.
Old Dec 25, 2006 | 08:54 PM
MIAPLAYA's Avatar
MIAPLAYA
The Turbonetics boost control is not controlled by the ECU and the stock ECU has no ability or provisions for electronic boost control.. The only way to reduce boost pressure is to add a boost controller and lower psi spring to the wastegate. Best case they could only hit 4 PSI. Although with this you could set the rev limiter to 2500 RPMs and they wouldn't be able to do much.
Old Dec 27, 2006 | 07:39 AM
MardiGrasMax's Avatar
MardiGrasMax
Can the UPREV ECU do anything for the auto trans torque managment that holds the car back at launch etc?
Old Dec 29, 2006 | 09:33 PM
bofa's Avatar
bofa
What do you guys do for peeps w/out cruise control?
Old Dec 30, 2006 | 05:32 PM
z-u-later's Avatar
z-u-later
You have to honk your horn and turn on the rear windshield wiper to engage the map switch . . . this must be synchronized.
Old Jan 7, 2007 | 10:22 AM
PunKidd's Avatar
PunKidd
The UpRev reflash hardware/software was developed in house from the ground up by reverse engineering the software on the ECU. And no the TN / AAM / TS / TechTom system does not have the ability to store alternate maps on the ECU.
BTW: 05 and newer ECUs have room for 5 alternate maps . Got N2O combinations ?
Actually we can limit the amount of boost by modifying the electronic throttle control. It doesn’t matter what the spring pressure is, if the throttle body only opens 10% @ wide open throttle you’re still not going to get any boost . Rev limiting does work pretty well too.
No TCU reflash yet, but it’s on the list to get done.
^^^ That could work, but seriously a solution is in the works.
Keep the Qs coming
Jared@UpRev.com
Old Mar 5, 2007 | 10:58 AM
  #38
dovla's Avatar
dovla
Originally Posted by PunKidd
Keep the Qs coming
Jared@UpRev.com
Can all four blinkers (hazard) be turned on automatically while under hard braking? With Brembo I really miss this feature.
Old Mar 5, 2007 | 01:36 PM
  #39
rocks's Avatar
rocks
To bad no one will release software like this in a standalone package. Hell they could make it only usable on one ecu by having it attached to the VIN number in each car. People would pay extreamly good money for something like this.
Old Mar 6, 2007 | 04:06 AM
  #40
WalkerT's Avatar
WalkerT
Professional
what if you have a base with out those buttons?
