Utec Map Needed for Break-in??
Old Jan 20, 2007 | 02:54 PM
brooke's Avatar
brooke
Default Utec Map Needed for Break-in??
Well I have finally finished installing my new motor and now I'm in need of a map until I can break it in and then have it tuned.. Thanks again for any help...
Here is my setup:
Aps TT
650cc Injectors
3 1/2 Aps Test Pipes
Aps Duel Exhaust
Thanks,
brooke
Old Jan 21, 2007 | 04:29 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
hey man, just about any map will work in your utec as long as you get the 0% column straight and not AT ALL get into boost...
around -17 in the 0% column should work, if not, check your AFR and plus or minus till you get around 14.7 on your wideband at idle, put your fuel pressure at 49 -50 at idle as well...
Old Jan 21, 2007 | 07:51 AM
brooke's Avatar
brooke
I don't think I can adjust my fuel pressure since I only have the aps fuel system that came with my kit.. To be honest I would rather have a map that matches my setup rather than take any chances with a 10k plus motor.. I still can't believe after doing all of the work myself after swapping motors etc that the only thing stopping me from running it is a map for my utec until I can break it in for a custom tune..
brooke
Old Jan 21, 2007 | 12:07 PM
al v's Avatar
al v
brooke
With the aps fuel system you can get around 450rwhp max ( in a low compression motor ),and you can get this power, with the aps bosch 440cc injectors.
You need a complete fuel return for those 650cc injectors , because the stock fuel feed is very restrictive.
Old Jan 21, 2007 | 04:52 PM
Gators2001's Avatar
Gators2001
UTEC website has a map for 750CC injectors.... thats closer then starting from scratch
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
