UTEC NA Map.
Old Feb 15, 2007 | 07:50 AM
rocks's Avatar
rocks
Default UTEC NA Map.
Would anyone happend to have a NA map that mirrors the stock timing on the ecu and the utec transition? Or if not how can I see the stock ECU timing to make it the same on the utec. The 3krpm hesitation has to go.
Old Feb 15, 2007 | 04:20 PM
peptidbond's Avatar
peptidbond
The UTEC will log the stock timing. If you want to use stock timing, then just put "ECU" in the map cells.
Old Feb 15, 2007 | 05:29 PM
rocks's Avatar
rocks
Thanks, i was wondering if i could do that across the whole map. Ill give it a try.
Old Feb 18, 2007 | 07:24 AM
peptidbond's Avatar
peptidbond
Sure can. Obviously, you use "ECU" for the timing map. I don't think you do that for the fuel map. However, we are not talking fuel.
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
