Timing issue
Old Apr 24, 2007 | 07:55 PM
Payco's Avatar
Payco
Default Timing issue
I have a 06 z with greddy TT, dump pipes and E-manage Ultimate, and I can't tune my car because every time the car makes boost the ecu retard timing. In the EU logger it says the the timing drops to -80, -132 range, is that even possible?, The car is running A/f in the 11 range until it retards timing. No mater what I do it keeps retarding.
I have checked every parameter and put every map in 0 and the car keeps doing the same thing. Have anyone experience this problem ??
I don't know what to do next. Any advice would be appreciated.
Thanks !
Old Apr 25, 2007 | 12:06 PM
Payco's Avatar
Payco
Anyone ???
Old Apr 25, 2007 | 07:28 PM
SmokyTyrz's Avatar
SmokyTyrz
Maybe timing is being pulled for a reason? Take it to a pro tuner to have it looked at.
Old Apr 29, 2007 | 11:49 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I know from first hand experience that the EU is not very good at adjusting timing.
What does your timing map look like? If it's all retard then it should be ok, but I could be wrong.
In any case, your best choice would be to ditch the EU in favor of something else... UTEC for example
Old Apr 30, 2007 | 04:25 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
Thanks !
take it to a tuner and have it tuned. you will mess it up if you keep trying to boost it...
Old May 4, 2007 | 04:31 PM
Payco's Avatar
Payco
I take my car to a local tuner, and he doesn't found any problem with the wiring or the program but the car still keeps retarding timing from 3500 rpm and up, with load or without it. No matter what I do the car keeps doing it. I remove the EU and check the timing with a ODB II scanner and the timing is OK. Any advice on what I can do with my EU?
Old May 4, 2007 | 05:07 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I'll ask again, what does your timing map look like? are you adding timing, or subtracting, from stock?
Old May 4, 2007 | 05:12 PM
Payco's Avatar
Payco
Right now everything is in 0.
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
