View Poll Results: greddy e-manage or technosquare reflash?
greddy e-manage
48
34.29%
48
34.29%
Other
44
31.43%
Voters: 140. You may not vote on this poll
greddy e-manage OR technosquare???
Old May 22, 2007 | 03:48 PM
savefatkids's Avatar
savefatkids
Default greddy e-manage OR technosquare???
my car is NA. so far i have aem CAI, motordyne 5/16 spacer,and a true dual custom exhaust. im paning on gettign headers a HFC this month next thing i want to do is get a tune. what would be better? greddy emanage or technosquare? what are the pros and cons of each? and what are the prices
Old May 22, 2007 | 04:18 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Start out by searching
Old May 22, 2007 | 04:19 PM
AGent_SaMo's Avatar
AGent_SaMo
Emanage ultimate
Old May 22, 2007 | 04:24 PM
Fluid1's Avatar
Fluid1
Commodore 64
DevildogCO1's Avatar
DevildogCO1
Aam
Old May 22, 2007 | 04:32 PM
350ZV3's Avatar
350ZV3
I dont have an opinion on the greddy option for the simple fact I dont have it. But I assume the logical answer to this product is are you hands on? The greddy will give you the ability to play with your car at home when you want to. The flash is a one time shot that should be done after all mods are done and done by an expert at a shop only so back and forth mailing is eliminated. I for one dont like tunning my cars and I can afford to do all my upgrades at once instead of monthly or yearly upgrades. If you are still upgrading your car or have plans to definately do so in future dont do the flash. Very costly when you add new items and have to reflash.
I've done the flash and heres my opinion on it. I definately don't recommend "mail-order" flashes. It will at least take a trip back in forth when/if you check the a/f and it's not to your VE. But reflashing can work just fine if the shop has your car (I did mine at PalmBeach Performance Nissan dealership. Case in point TechnoSquare. Only thing bad imo is you can't adj. yourself w/o the $$ of hardware/software and license. Mine worked out great but I let the experts make the changes then picked up my car. And I did the flash after all my upgrades were done (very important). If you decide to add somthing new (major mods only) you will have to reflash.
Old May 22, 2007 | 04:39 PM
savefatkids
Originally Posted by 350ZV3
I dont have an opinion on the greddy option for the simple fact I dont have it. But I assume the logical answer to this product is are you hands on? The greddy will give you the ability to play with your car at home when you want to. The flash is a one time shot that should be done by an expert at a shop only. I for one dont like tunning my cars. I like to buy and use.
I've done the flash and heres my opinion on it. I definately don't recommend "mail-order" flashes. It will at least take a trip back in forth when/if you check the a/f and it's not to your VE. But reflashing can work just fine if the shop has your car (I did mine at PalmBeach Performance Nissan dealership. Case in point TechnoSquare. Only thing bad imo is you can't adj. yourself w/o the $$ of hardware/software and license. Mine worked out great but I let the experts make the changes. And I did the flash after all my upgrades were done. If you decide to add somthing new (major mods only) you will have to reflash.
im in CA less than an hour drive to technosquare.. and after i do headers and HFC i dont plan on any other mods. so i wouldnt need another tune. overall how did you like the reflash ? how much power did you get out of it?
Old May 22, 2007 | 04:40 PM
savefatkids
oh and my cars a g35 5at
Old May 22, 2007 | 04:49 PM
350ZV3's Avatar
350ZV3
For any Z with major NA mods like intake, plenum, headers, exhaust, etc., I think the ECU flash is really effective. I definately felt a difference and have heard many others have said they gained more power than claimed by TechnoSquare themselves. This is because these NA mods TEND to make you run lean most of the time. Some dont. Those running lean will obviously see a bigger boost. Also, the increased rev limiter plays really well with a plenum. Ive been very happy with it.
Old May 22, 2007 | 04:52 PM
savefatkids
For a Z with some major NA mods (intake, plenum, headers, exhaust, etc), I would say that the ECU flash is really effective. I definately felt a difference and have heard many others have stated that they get more power than claimed by TechnoSquare. This is because these NA mods TEND to make you run lean, but not always. Those running lean will obviously see a bigger boost. Also, the increased rev limiter plays really well with a plenum. Ive been happy with it.
thanks, i pretty much have my mind set on the technosquare, since im not looking to spend too much money
Old May 22, 2007 | 04:57 PM
enthuZast's Avatar
enthuZast
Old May 22, 2007 | 05:18 PM
streetracer's Avatar
streetracer
My vote goes to Hydra EMS.
Old May 22, 2007 | 05:39 PM
Abishop's Avatar
Abishop
utec
Old May 22, 2007 | 05:49 PM
kwiker's Avatar
kwiker
Shift_Dorifto
hondata or maybe even uberdata if you want to make some serious n/a power
Old May 22, 2007 | 07:13 PM
savefatkids
too bad HONDAta is for hondas...
D15na's Avatar
D15na
utec...
Old May 22, 2007 | 07:25 PM
skaterbasist's Avatar
skaterbasist
UTEC is not worth the price if you plan on staying NA.
As far as an EMS/ECU, a TS reflash should do the job right.
Old May 22, 2007 | 07:35 PM
Fooshe's Avatar
Fooshe
No two ways about it...make the drive and go to technosquare. There is something to be said for the old school Japanese mantality.
Old May 22, 2007 | 09:13 PM
mavtais's Avatar
mavtais
Mantality - noun. The existence of manly thoughts in a person's mind, often wanting things to be bigger, better, and more personalized. This word was derived from combining the two words man + mentality. Japanese Mantality, as mentioned in this case, means the existence of manly thoughts in a person's mind, often wanting things to be bigger, better, and more personalized in the most efficient and cost-effective way possible.
You heard it here first
Wikipedia, please pay me $.02 everytime someone searches this word or uses it in a post, song title, or is heard on the radio.
Old May 23, 2007 | 07:21 AM
Havok_RLS2's Avatar
Havok_RLS2
UTEC. Don't waste your time with the other junk.
