Tuning with no turbo kit.
Old May 26, 2007 | 11:13 AM
redline350ZZ's Avatar
redline350ZZ
Default Tuning with no turbo kit.
Well I am removing my Turbonetics kit at this moment and will need a retune. I have 9.0 Arias and GTM Turbo cams. Going from the TN downloaded map to a NA tune any thing I should tell my tuner?
Old May 27, 2007 | 01:39 PM
DaveFunction2ND's Avatar
DaveFunction2ND
If you are going to the stock injectors and fuel pump then it will run just fine on the regular tune. If you keep the TN Injectors and 255 he is going to have to remap the fuel curve slightly. The motor will run just fine on stock timing curves but if you're looking to get optomized power then he should retune both timing and fuel.
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
