Utec On Map
Old Sep 7, 2007 | 07:01 AM
moshny's Avatar
moshny
Default Utec On Map
Hi All,
Does anybody tried to program the UTEC to work only by MAP sensor?
From idle to redline, from vacuum to boost, without MAF at all?
Thanks.
Old Sep 8, 2007 | 01:51 PM
NETSHARK's Avatar
NETSHARK
i guess its not possible because the UTEC is programed to run in Mass Air Mode (MAF) at 0% load site and Speed Density Mode (MAP) at the rest Load sites.
Old Sep 13, 2007 | 01:38 AM
moshny's Avatar
moshny
No, If you program it to run in OpenLoop from full vacuum, it must work without MAF, I'm trying to do it now, but have some problems with idle and very low load.
The car is Greddy Twin Turbo, 18psi of boost, 1000cc injectors.
At high loads everything is normal, but very rich near idle.
Old Sep 13, 2007 | 08:17 AM
G35asian's Avatar
G35asian
Thats what the 0% column and injector scaling feature is for. Make sure that your injectors are scaled correctly and if you need to take out fuel for idle, change the input under 1k rpms in the 0% column. Scaling should do the trick though.
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
