Target A/F when Tuning Forced Induction?
Old Nov 2, 2007 | 04:53 AM
  #41
Ziggyrama's Avatar
Ziggyrama
Originally Posted by VitViper
I'm just curious... cause putting my stock intakes back on the car runs noticeably stronger in the low end and mid range. And the whole powerband is just smoother.
Following up on what Samurai said about your intake, are you running with a MAF or are you tuning using speed density?
Intakes with MAFs can be tricky. It's not always just about the filter. Flow characteristics are very important, especially around the MAF sensor. Generally, shorter intakes that have a plenum of some kind not too far away from the TB will give you better low end and perceived 'throttle response'. Stock Z intake is somewhat of a compromise but it seems to work very well.
Old Jan 5, 2008 | 04:51 PM
  #42
zerosec's Avatar
zerosec
This may seem a little off topic, but it would really help me out if you guys were to give me the stock ignition timing curve on a 2003-2006 350Z engine - assuming of course the use of 93 octane gas. Or, to rephrase my question, what's the most ignition timing you can run on a STOCK N/A Z before detonation rears its ugly head?
Old Jan 5, 2008 | 05:18 PM
  #43
jining's Avatar
jining
I would think it would vary motor to motor and also ambient tempurature would also be a factor no?
Old Jan 5, 2008 | 05:34 PM
  #44
zerosec's Avatar
zerosec
I'm just asking for the values of the look-up tables in the stock factory ECU...
Old Feb 20, 2010 | 06:55 PM
  #45
akks350z's Avatar
akks350z
some good info for you self tuners
Old Feb 26, 2010 | 12:27 PM
  #46
RA11325's Avatar
RA11325
I run mine in the High 10's. Been making awesome power on the stock DE bottem end since 2006.
Old Mar 2, 2010 | 12:45 PM
  #47
mgrotel's Avatar
mgrotel
subscribed
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
