UTEC-Tuned STS - Leaning Out to 21 AFR on Low MAP!!!
Old Nov 9, 2007 | 08:29 AM
gothchick's Avatar
gothchick
It's either clogged injectors, or a leaky plenum. My .02 cents...
Old Nov 9, 2007 | 12:12 PM
Snow-G's Avatar
Snow-G
Originally Posted by athenG
Isn't that temp correction is a global parameter? His problem is only on the 0 column and seem to be fine once he hit load. Does Utec Temp Compensation also affect the 0 Column? I'm also curious why his 0 Fuel Column is way different than mine. My 0 column is around -4.3 to -4.5 and his is around -12 to -16. My Idle and part-throttle under no boost/load has an A/F from 13-15.
I just ran into this problem yesterday...under idle or o load the car struggles with constant idle. It's weird, the temp in the morning was about 26 and the car ran fine. Later that afternoon the temp was around 40 and problems started. My normal idle will be 700, when things started happening I noticed it at 650 and wanting to stall. Usually when I turn the AC on the rpm will raise another 150 or so. This seemed to work until I could get home to check it out. Now at 850-900rpm, I come to a stop light and the car wants to die again! Havent had a chance to dig into it, but I will on Sat. I hope its just a leak.
So I took the upper and lower plenum apart and changed out the gasket. Everything looked good. Started her up, got to normal temp and same low idle and shortly after stall when in first gear. I think Ive got a bad injector or coil. I dunno.
Old Nov 15, 2007 | 05:01 AM
goosegoose's Avatar
goosegoose
Here's an update.
On Monday night, I tried to tune out the problems by modifying the 0% columns in the UTEC. Nothing seemed to make any difference, in idle quality and low throttle performance, so I changed all the values back to the way they were before.
On Tuesday, i took the car to my mechanics to check for a plenum leak. We hooked up a smoke machine to the plenum, and pumped in the smoke to see if any of it seeped out in places where it wasn't supposed to. No leaks.
On Wednesday, we decided to check the throttle body. After taking a look at it, we were all surprised to see it was black and dirty as all hell. I have a feeling this is the motor oil residue from the time when my oil return line was leaking into the turbo months ago. Cleaned everything up. Started the car. It now idles very smoothly. The AFR numbers all seem to be more normal. I am no longer getting 21 AFR at part throttle. I'll have to see what happens today when i take it on the road to data log.
So that's the good news.
The bad news is that i now have an engine code lamp.
P0171
System Too Lean Bank 1
Any advice?
Old Nov 15, 2007 | 06:53 AM
gothchick's Avatar
gothchick
Glad the AFR / idle problem is fixed...
For the P0171 - Do you have hi flow cats, or test pipes?
Old Nov 15, 2007 | 06:54 AM
goosegoose's Avatar
goosegoose
Nope. Stock headers, stock cats, stock y-pipe.
Old Nov 15, 2007 | 07:02 AM
gothchick's Avatar
gothchick
Hmmm, maybe try resetting the ecu? Maybe take it somewhere that has a sniffer to verify what the AFR is on bank 1?
I'm assuming your wideband is on bank 2?
Old Nov 15, 2007 | 07:10 AM
goosegoose's Avatar
goosegoose
My Innovate Wideband is on the driver's side bank. Is that bank1 or bank 2?
Old Nov 15, 2007 | 08:35 AM
gothchick's Avatar
gothchick
Bank 1 = pass side
Bank 2 = driver side
Old Nov 15, 2007 | 08:38 AM
goosegoose's Avatar
goosegoose
Bank 1 = pass side
So according to the CEL code, i am running lean on the passenger side.
I'll plug some sniffers and scanners in to the vehicle today to see if I can tune it out.
Old Nov 15, 2007 | 09:13 AM
gothchick's Avatar
gothchick
Unfortunately, UTEC can't tune bank 1 & 2 independently. It tunes both banks the same way at the same time.
So if you're getting a code only on one bank, I'm guessing something tripped the sensor (plenum problem, leaker header, bad cat, etc), or maybe the sensor is bad. But to help narrow it down, I'd definitely verify what the AFR really is on that bank.
Old Nov 20, 2007 | 07:03 AM
goosegoose's Avatar
goosegoose
Some more updates.
Last Friday, we did a full fuel injector cleaning, and cleared the codes.
By Saturday, the CHECK ENGINE LIGHT came back on.
On Monday, we plugged in a scanner to check the codes, and this time, there were two errors. Both banks 1 and bank 2 were being reported as too lean.
I think think this is progress?
Since then, I have had cleared the codes again, and raised all the 0% fuel values in my UTEC by +3. I have driven 40 miles on this so far, and there is no light yet.
Any thoughts?
Old Nov 20, 2007 | 09:06 AM
athenG's Avatar
athenG
So is your A/F spot on again? I'll keep an eye on your A/F and see if things changes. You mentioned that your A/F has been dipping into the low 10's, I would lean that a little bit around 11.1 for extra safety. Your timing seem to be conservative enough (more conservative than mine) and I only get knock above 11.7 A/F.
Do you have an ODBII reader? I think you should always have one in your trunk. I have used mine so many times and it's well worth it.
Old Nov 20, 2007 | 10:54 AM
Julian@MRC's Avatar
Julian@MRC
Originally Posted by goosegoose
Some more updates.
Any thoughts?
INJECTORS...
Old Nov 20, 2007 | 10:55 AM
goosegoose's Avatar
goosegoose
Originally Posted by MRC Motorsports
INJECTORS...
Is it alot of work to change the injectors?
Old Nov 20, 2007 | 11:58 AM
athenG's Avatar
athenG
not that hard, maybe 45 mins. But is your A/F still in lala land?
Injector Install is on Page 14 of the manual.
Old Nov 26, 2007 | 05:03 AM
goosegoose's Avatar
goosegoose
My AFR is not spot on, but after about 400 miles, the check engine light has not come back.
In the end, it looked like the Throttle Body and Fuel Injector cleaning fixed the rough idle and cruising problems, and adding fuel through the UTEC fixed the check engine light problem.
I think I will need to have everything comprehensively re-tuned after winter.
Old Nov 26, 2007 | 06:41 AM
athenG's Avatar
athenG
good luck on your journey I'm starting to collect some parts for spring. I just got some TP and I'm looking for a good Water/Meth kit and I'll have them installed and tune together with my FMIC I got from Gurgen.
350Z_Al
Oct 29, 2020 07:44 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
