to reflash or not to reflash thats the question
Old Apr 30, 2008 | 05:27 PM
camrron03z's Avatar
camrron03z
Default to reflash or not to reflash thats the question
I have been reading for hours sorry if this has been answered, I only have a bassani exhuast and plenum spacers do i need a reflash. And also how do I reset my ECU
Old Apr 30, 2008 | 05:29 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
You don't have to, but if you want you can.
Old Apr 30, 2008 | 05:33 PM
rkemp1's Avatar
rkemp1
A reflash can give you a little more power and throttle response even if your not modded and can remove your top speed limiter as well. But you may see slightly better gains if you reflash after doing all of your bolt ons first.
Old Apr 30, 2008 | 05:35 PM
CSF's Avatar
CSF
if you plan on doing more NA mods...you may want to wait.
if you're done modding...i would recommend it.
Old Apr 30, 2008 | 05:38 PM
Chebosto's Avatar
Chebosto
the two mods that affect AFR the most, historically have been plenum spacers and high flow cats.
if you are doing either or both, a reflash to tune your car is suggested to optimize power gains from both modifications.
Old May 1, 2008 | 07:20 AM
UpRev's Avatar
UpRev
A reflash helps even on non-modified cars. The gains you may see when you first install your parts will diminish slightly as the ECU re-learns it's way around them. The ECU has preset targets that it will try to hit, so it will learn its way around most basic bolt ons. The simple solution to this is to reflash it. Set new targets based on the mods you have.
Recommending that someone wait till they have all their bolt ons done before they reflash is a good idea if they can't modify their flash later on. If you're picking a re-flash that requires you to send in your ECU, don't expect a later update to be free. If you chose a re-flash that allows you to request a free update when you add your future bolt ons, then you'd be wise to purchase that at any time, including if your car is completely stock.
fyi: we offer free eTunes. :-)
Old May 1, 2008 | 12:11 PM
Highway Riding's Avatar
Highway Riding
any mechanic with a error code scanner can just reset it. If the check engine light didnt come on i'm not sure if that's needed. BUMP for knowledgable ppl to chime in..
Old May 1, 2008 | 07:19 PM
CSF's Avatar
CSF
for ECU reset:
http://www.technosquareinc.com/350reset.htm
Old May 2, 2008 | 04:46 AM
Highway Riding
Originally Posted by CSF
interesting.. thx
Old May 2, 2008 | 08:46 AM
gothchick's Avatar
gothchick
I reflashed mine so the ECU would stop trying to "adjust" around my UTEC tune. Car runs much more consistently now... :-)
Old May 5, 2008 | 05:06 PM
camrron03z's Avatar
camrron03z
Thanks for all the help, my bassani exhaust just got here today, so I can just follow those steps in the link and it will reflash or reset what I need?
Old May 6, 2008 | 07:34 AM
UpRev's Avatar
UpRev
Those steps just reset your ECU. Your ECU has learned it's parameters to hit the Targets set by Nissan, it will learn to hit them again whether you reset it our not. It may take a bit longer if you don't reset it. Either way, the ECU will figure out how to adjust itself to hit the stock targets again and you will eventually lose the power gained by your bolt on part. The only way to stop that from happening is to either get a flash tune done to your stock ECU, or get a piggy back ECU to tune your car.
Old May 7, 2008 | 10:48 AM
Fluid1's Avatar
Fluid1
UpRev. Will you please respond to my PM.
Your customer service is the worst that I have experienced. This makes two separate occasions that I have expressed interest in your product, and my email and PM inquries go completely unanswered. Are you not motivated to sell your product?
Amazing.
Old May 7, 2008 | 02:33 PM
__jb's Avatar
__jb
Z + Rear Seat
If you don't flash your ECU to new targets, your ECU will keep learning around your mods to make the a/f more emissions friendly.
Why install performance mods and then let your ECU just dumb them down?
Old May 7, 2008 | 02:59 PM
UpRev's Avatar
UpRev
Amazing.
Not amazing, busy, we're very busy. You didn't e-mail me this time, I check my e-mail 3x a day minimum. You sent a PM on a board I don't always get a chance to check or I may be waiting on info to respond to you from another person here at Uprev.
Old May 8, 2008 | 04:16 AM
Fluid1's Avatar
Fluid1
Perhaps you'd like me to quote your posts on this website 5 days after my PM, when it was still unanswered? You ahve time to post to create hype for your product but you ignore paying customers?
What could you have possibly been waiting on? You had already confirmed pretty much everything I wanted to know in the thread previously. Shall I post what you said, to refresh your menory, and then match it to the PM I sent you? I can easily make this information public if you so choose.
Just man up and start working on customer service. Hyping your product online and then ignoring customers is not the way to go. Do you want to be the guy on the forums who has a rep for not responding to people? how long do you think you'll last doing that?
Old May 8, 2008 | 05:59 AM
raditz's Avatar
raditz
Uprev, so you can confirm me that the stock ECU will correct values even at WOT? many tuners here in Sapin, told me that the ECUs only makes corrections when they are un Closed Loop Mode, and that is below +/-3000 rpm and low loads. At WOT they say that there is no auto learning.
Old May 8, 2008 | 06:03 AM
felpudiano's Avatar
felpudiano
jajja, mariquita!!!!!
Old May 8, 2008 | 06:32 AM
raditz's Avatar
raditz
Estoy preguntando esto por Toni, pq si es cierto q la ECU corrige valores a plena carga (q parece q si) con la ECU q le van a montar en Sanz Sport, irá perdiendo poco a poco los resultados.
Old May 8, 2008 | 10:07 AM
Asian Invasian's Avatar
Asian Invasian
You said you have been reading for hours about the reflashes... you should be able to answer your own question...
