UTEC Tuner
Old Nov 16, 2008 | 10:42 AM
BoostedProbe's Avatar
BoostedProbe
Default UTEC Tuner
Got a a question for you UTEC guys. I am picking up the UTEC tuner with a wideband and all the other stuff needed to have it running with the UTEC. I already have the UTEC with MAP sensor, selector and cables with software.
Is it pissible to use a wideband gauge with this setup? So I would have the Tuner and a gauge share one O2 sensor.
Thanks
Old Nov 16, 2008 | 11:01 AM
Chaser720's Avatar
Chaser720
Lemoned Z
Old Nov 16, 2008 | 03:27 PM
athenG's Avatar
athenG
Yes, you can get one of this http://www.dynotunenitrous.com/store...?idproduct=170. The tuner has an output for the A/F. I believe JonnyC is using an external gauge with his tuner.
Old Nov 18, 2008 | 09:29 AM
NETSHARK's Avatar
NETSHARK
another option is the Innovate DB Gauge it comes in Red/Blue LED and it matches the Defi Gauges very well it will go fully black when u turn it off.
Old Feb 20, 2009 | 09:42 AM
Havok_RLS2's Avatar
Havok_RLS2
Talking
Has anyone tried this one yet with the Turner WB? It said to work on a 0-5v signal.
52 mm Electrical Digital Air/Fuel Ratio &Volt Gauge
This is the first of one of the coolest product lines we are developing. This digital gauge is like having two gauges in one. We started with a standard Air Fuel Gauge and instead of wasting the valuable real estate in the center of the gauge with our logo we utilized that space to display the A/F & Volts Digitally. It will display Air/Fuel ratio around the outside while digitally displaying both A/F or volts. When the red "volt" light comes on you know you are reading volts (displays for 50 seconds) and if the light is not on the digital display is Air Fuel Ratio. Using a switch on the back you can even turn off the volt feature and run AFR all the time.
*NEW FEATURE*
This gauge can be set to read narrow band or wideband (0-5v) with the flick of a switch in the back of the gauge. That means that you can now use this gauge with your stock narrow band O2 sensor or use it with a control unit like innovate to display a 0-5v signal.
NOTE: This cannot be used as a stand along wideband AFR with a bosch wideband 5 wire heated O2 sensor unless you are using a controller! (Our complete wideband AFR gauge is due out within months)
http://prosportgauges.com/digital-ai...olt-gauge.aspx
This is the one I'd like to buy but I'd like you guys input.
Old Feb 20, 2009 | 11:53 AM
QuadCam's Avatar
QuadCam
replied to on other thread
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
35reilly
Sep 28, 2015 07:42 AM
