***need help tuning an emanage blue!!!!!
Old Dec 3, 2008 | 03:58 PM
350ZnismoPR's Avatar
350ZnismoPR
Default ***need help tuning an emanage blue!!!!!
hey, i just bought an emanage, i am N/A so i just want to get out as much as i can from my mods. The problem is i have the true dual exhaust and i need two widebands to tune it (i dont wanna spend another $230 again, i already bought one). another problem, the guy who is going to tune it, said i need a fuel pressure regulator, i was told the vq35de has two, and that i needed to join them into the aftermarket one i will instal. what can i do???
Old Dec 4, 2008 | 08:24 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Dec 4, 2008 | 12:18 PM
athenG's Avatar
athenG
FPR is nice but it is not a must, your tuner is asking to much. If you already have 1 WB then just tune using bank2 (driver side) since bank2 run leaner on WOT.
Old Dec 4, 2008 | 01:28 PM
G35Soul's Avatar
G35Soul
+1... My thoughts exactly! Also, FPR usually not needed for most NA bolt-on mods
Old Dec 4, 2008 | 01:35 PM
350ZnismoPR
so bank2 is the header from the driver side? and Doesn't it affect the tune to adjust using only the reading from the bank2?
Thanks guys.
Old Dec 4, 2008 | 03:00 PM
athenG's Avatar
athenG
Thanks guys.
Emanage only scale of the ECU # anyways so you dont have full control of your fuel nor you have any kind of control with your ignition. Emanage blue just use ECU timing not like the Ultimate which can control Ignition/Timing. Majority of tuner here just tune using the driverside (bank2) since that is leaner and has a greater chance of detonating first on WOT.
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
