AccessTUNER for Nissan/Infinity available NOW!
Old Jul 13, 2009 | 08:26 PM
NETSHARK's Avatar
NETSHARK
Originally Posted by SmallTuner
USDM !!
what about the middle east spec ? we are having hard time moding the z here Diffrenet ECU spec and EPP-ROM chip
im thinking to change all my harness BCM,ECU everything to a US spec
Nyahahahaha
Originally Posted by Sharif@Forged
Where just upgraded our Pro Tuner status to support the 350Z/G35/G37/370Z. We've been tuning the GT-R's and EvoX's for months. Great to have another good reflashing optioning. I will make sure to keep the you all posted, especially as it relates to FI on the 350Z.
Sharif Can i disable the annoying O2 CEL i mean can i chose which DTCs to disable, and can i use it with UTEC to run bigger Injectors so i don`t have to press the gas pedal to start up the car each time (Hot Start Up Issue), thanks big bro.
one more question for Cobb Tuning Guys, how can i know if my Vehicle is one of the Supported Automatic G35s BTW mine is Coupe 2004 but maybe its 2004.5 too who knows :1
Thanks.
Old Jul 13, 2009 | 09:32 PM
Frostydc4's Avatar
Frostydc4
You have PM.
Old Jul 14, 2009 | 02:37 AM
maXmood's Avatar
maXmood
Under Boost!
Originally Posted by Travis@COBB
TCM is Transmission Control Module. And sorry for the confusion but we do support the Automatic 350Z. Some of the Automatic G35s we do not support, my apologies. Yes the AccessPORT will work perfectly on your car.
Travis
COBB Tuning
Thanks Travis... Great to know it will work!!
which year model maps should i download instead?
thnx
Old Jul 14, 2009 | 02:50 AM
Ghost_shift's Avatar
Ghost_shift
Price for Cobb Tuner Race for 2008 350z shipped to 34947 please.
Also, can this remove the cell for no cats permanently like the reflashes or Osiris?
Old Jul 14, 2009 | 06:04 AM
0jiggy0's Avatar
0jiggy0
Price is 695 shipped i think.
Sharif when you get a chance could you let us know how you like it vs the other options available, like the Uprev.
Old Jul 14, 2009 | 10:21 AM
Travis@COBB's Avatar
Travis@COBB
Airflow is always the limiting factor in horsepower production. This is the problem with NA tuning. In order to make more power you need to get more air into the engine. You can acheive this by increasing the volumetric efficiency of the engine with intakes and header/exhaust. But then the engine hits its physical limit of how much air it can flow, then you have to look at cams and headwork and higher compression, but even there are limits here. A turbocharger or supercharger is really the best and most economical way to drastically increase power production (airflow).
Increasing the size of the injectors isn't going to increase power potential unless you also drastically increase the airflow into the engine. More fuel needs to mix with more air.
Travis
COBB Tuning
Old Jul 14, 2009 | 12:32 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^so how much power AP can tune and handle(VQ)? And what size injectors AP can handle?
And why you guys not offering modif maf sensor?
Also, what about knock protection?
(asking about FI)
couple months ago I asked these same questions to local cobb guys, just want to hear from you as well.
Old Jul 14, 2009 | 01:15 PM
Travis@COBB
The AP can tune to basically unlimited horsepower. The injector size is goinng to be more or less limited to the drivers in the stock ECU. Since the AccessPORT is reprogramming the the ECU and using the ECU to tune with there are some limitations inherent in the system, so I would hate to put a solid number on it, however, on other platforms (Subaru, EVO) AccessPORT-tuned cars have made in excess of 500whp.
While we do not offer a modified MAF housing for the Z, you can scale the MAF with the AccessTUNER software for a larger MAF housing or modified housing.
Travis
COBB Tuning
Old Jul 15, 2009 | 07:08 PM
NETSHARK's Avatar
NETSHARK
still u guys didn`t answer the DTCs disable function question :1
Old Jul 16, 2009 | 08:53 AM
Ghost_shift
+99
Old Jul 16, 2009 | 02:44 PM
Travis@COBB
You can disable the secondary O2 CEL with the AccessTUNER Race software. The AccessPORT unit itself can only clear codes.
Travis
COBB Tuning
Old Jul 16, 2009 | 07:50 PM
NETSHARK's Avatar
NETSHARK
Travis
COBB Tuning
Am Getting AccessPort even though i got a UTEC but it will be very useful to fine tune lot of stuff not to mention removing the limiters and disabling the CELs this two things in my book sit it aside from other flash options as the best bang for the $$ today where you guys been hiding before ?
RACEWAY PARK
North East
Mar 19, 2007 09:12 PM
RACEWAY PARK
North East
125
Jul 22, 2006 06:49 PM
se_nismo
Southern California
Jan 15, 2006 06:16 PM
10secapsttz
North East
160
Jul 3, 2005 03:06 PM
