Can my tunes be optimized?
Old Jun 16, 2010 | 06:42 PM
rich2342's Avatar
rich2342
Question Can my Osiris maps be optimized?
Hey guys,
Can someone knowledgable take a look at each of my osiris tuned maps and see if there is any rpm point where the a/f is out of range or should/could be tweaked for better power?
Im concerned as ive been noticing excessive carbon build up on the exhaust after only a few days time.
Am I running in the proper a/f ranges?
There are two plots of data points from dyno runs.
-Map 5 is the most agressive map 93Octane + timing advance
-Map 1 is a tuned 93 Octane map.
File Type: txt
Old Jun 16, 2010 | 08:25 PM
hellsoldiers08's Avatar
hellsoldiers08
Have you tried getting on a dyno and to see if there is any ups or dips in the rpm band? Also i notice on the thing that at around 3,700 you go to 13 then next one back in the 12's. Im no tuner genius but that is something i would ask to see if it a ok thing.
Old Jun 18, 2010 | 12:38 AM
maXmood's Avatar
maXmood
Under Boost!
post your setup so we can at least have an idea of what you're running.
if you're stock, then everything looks normal to me.
Old Jun 18, 2010 | 04:08 PM
cdoxp800's Avatar
cdoxp800
From what your stating Map 5 is the most aggressive. Not sure how much timing is being ran, but there is such a small difference between 5 and 1 your really not going to see any big gains by messing with map 5.
Old Jun 19, 2010 | 04:08 AM
rich2342's Avatar
rich2342
Being n/a on a De, im not expecting big gains, lol.. Im curious about the a/f's at each rpm listed there. Just worried about not being at the ideal ranges at any given point, possibly being a little Rich.
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
