COBB Lean Spike
Old Dec 11, 2010 | 05:21 PM
kabro91's Avatar
kabro91
Default COBB Lean Spike
Hey guys Ive been using the COBB Stage 2+ map w/ K&N Filters, Bassani Catback and GTM TPs on an HR motor, and whenever I datalog I keep getting a 20 a/f spike when i cruise like if Im ever going and take my foot off the gas I hit a 20 spike, do you guys have any ideas as to what could be causing that??
Old Dec 11, 2010 | 05:55 PM
Italianjoe1's Avatar
Italianjoe1
stage 2+ is for aftermarket intakes. Go to the straight stage 2 map, same but without the maf adjustments.
The lean spikes to 20 are when the injectors shut off during coasting, normal and not dangerous. There is no stress on the motor at that point.
Old Dec 11, 2010 | 05:58 PM
kabro91's Avatar
kabro91
thanks alot man very helpful
Old Dec 11, 2010 | 06:04 PM
Italianjoe1
Are you tuning with the accessrace program as well? I've made some pretty nice improvements over the stock Cobb maps. I find them to be a bit on the 'safe' side, I was able to lean the car out, smooth out some transitions and get a much smoother, stronger pull all the way to 7500.
Old Dec 13, 2010 | 06:40 AM
str8dum1's Avatar
str8dum1
opps, already answered in post #2
its hard to understand your issue. so are you saying when you are cruising and take your foot off the gas you get a lean spike?
That is what happens when the injectors close when you take your foot off the gas.....
pdexta
Sep 14, 2015 11:27 AM
timzerofive
Southern California
Dec 10, 2002 12:02 PM
Stailey
Nov 19, 2002 04:03 PM
