2JZ-GTE best way tuning
Old Apr 19, 2011 | 05:48 PM
drivessidewayz's Avatar
drivessidewayz
Originally Posted by 0jiggy0
Forget the car, more pics of the house.
^^this
Old Apr 22, 2011 | 12:38 AM
scenehouser's Avatar
scenehouser
cool project dude. keep up the good work.
Old Apr 22, 2011 | 08:04 AM
CRIDDA's Avatar
CRIDDA
In for the build
Old Apr 22, 2011 | 08:28 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Sweet build, with a screen name like yours I thought a RB would be your choice of engines . I cant wait for more pictures
Old Apr 26, 2011 | 07:29 PM
Minus's Avatar
Minus
Right or wrong most 2JZ guys running a standalone are using AEM for tuning. Good luck. Looks like a fun project.
Old Apr 26, 2011 | 08:12 PM
INTIMAZY's Avatar
INTIMAZY
I hart you crazy Russians.
Is that a VVTI motor I see? Can't really tell from the second pic.
Do the mounts fit right into the crossmember? Looks like all you had to do was drill a new hole. Is there a v160 behind it?
Good luck. As much as I firmly believe in staying with one manufacturer for motor swaps, a 2JZ is just too sweet of a motor to pass up.
Old Apr 30, 2011 | 02:49 PM
KTran's Avatar
KTran
subscribed,
im in the same process on my 2jz33 drift build.
seemed like you did what i plan on doing.
the mounting points on the stock 2j engine mount bracket is off about 1 inch on each side, did you just notch the cross member to make the stock 2j mounts work?
also, im interested to see how you wire it up.
my z33 is just a bare shell, i dont plan on using any oem z inteior electronics, but i still have the body harness.
keep us updated,
thanks.
i plan on going stand alone via haltech pnp+custom engine wiring and racepak dash.
Old May 17, 2011 | 08:59 AM
John@z1's Avatar
John@z1
Z1 Motorsports
Very easy to see that's a VVTI engine.
Old May 17, 2011 | 12:35 PM
INTIMAZY's Avatar
INTIMAZY
Thanks
Couldn't tell on my phone screen.
Old Jun 29, 2011 | 06:19 AM
bnr34ru's Avatar
bnr34ru
please PM for info. i'll try to answer if my english is ok to you)))
Old Jun 29, 2011 | 11:33 PM
JDMStanced's Avatar
JDMStanced
how would you guys compare 2jz swap and LSx swap?
Old Jun 30, 2011 | 10:13 AM
themadhatterxxx's Avatar
themadhatterxxx
no **** dude, this was the first thing that popped into my mind when I saw that pic.
Haha dude looks like he has some $$$
Old Jun 30, 2011 | 10:30 PM
ITOzann's Avatar
ITOzann
cool!
Old Nov 20, 2011 | 03:41 AM
midz350's Avatar
midz350
Update?
Old Nov 20, 2011 | 04:03 AM
Spork's Avatar
Spork
Originally Posted by Row2K
am I the only one that read his post with a russian accent ... just saying
Not alone. Just opened the thread to do this.
Old Dec 13, 2011 | 09:32 AM
Resmarted's Avatar
Resmarted
UPDATE. NAO.
Jebote rusi sa 2jz swap.
Old Dec 30, 2011 | 08:45 PM
midz350's Avatar
midz350
Update right meow.
Old Dec 30, 2011 | 10:28 PM
  #38
Resmarted's Avatar
Resmarted
Originally Posted by midz350
Update right meow.
You going to post up a build thread? Or have I just missed it?
Going proper 2j?!
Old Dec 31, 2011 | 12:11 AM
  #39
midz350's Avatar
midz350
Going proper 2j?!
I will be getting the engine and tranny in the upcoming two weeks, hopefully. Will make thread then.
I found a complete 2JZ-GTE + R154 for only $2200
I want to see what happened with the OP since he used the OEM 2JZ engine mounts.
Also, I have an insane idea
Thinking about cutting away the VQ35 bell housing and use the new JWT adapter to replace the original front sealing cover and bolt the R154 bell housing to the adapter to connect the 350z tranny to the 2JZ.
The 350Z & Infiniti G came with a very strong 6-Speed transmission that is starting to show up more and more at the auto recyclers, making for a reasonably priced option for other high-powered Nissans. Unfortunately, it sports an integrated bell housing, making this conversion difficult at best. By scrounging an automatic tranny bell housing from an automatic that was fitted to the same motor you are adapting to, this adaptor ties everything together. Either the 07+ 350Z Concentric Release Bearing or an aftermarket C.R.C. (Tilton) can be used. The no longer used VQ35 bell housing is cut away and the new adaptor replaces the original front sealing cover. This adaptor can mount a 6-Speed to a VG30DE(TT), SR20DE, KA24DE, or VH45DE engine. Adaptors for the VK56 and others will be available soon after the release of this adaptor. Contact Ben for release date or other information. 619 442-0680
R154 bellhousing bolt pattern:
Kinda close
Old Dec 31, 2011 | 01:55 AM
  #40
Resmarted's Avatar
Resmarted
Kinda close
We were talking about that very mod earlier in this thread actually! And I've gone over this with buddies of mine too.
I think it's do-able, and those pictures kind of confirm it too. Although you are probably better off not cutting anything and having a custom adapter made (for strength). You'll need a custom driveshaft anyway.
Nice find too btw! Now just get yourself a nice big precision billet and you are set!
