uprev o2 questions
Old Dec 27, 2011 | 06:49 PM
R350Zz33's Avatar
R350Zz33
Default uprev o2 questions
So I have a 08 z tuned with uprev my o2 sensors are tuned off can I unplug my stock sensor and put my inovate wide band sensor in it with out a problem or does the ecu still need to see it there
Old Dec 28, 2011 | 02:24 PM
Zazz93's Avatar
Zazz93
I'd be hesitant to do that. Better to tap a new bung and attach the WB's there.
Old Dec 28, 2011 | 03:38 PM
R350Zz33's Avatar
R350Zz33
And why is that ? If there off I can just pull them out and save $140
Old Dec 28, 2011 | 05:02 PM
djamps's Avatar
djamps
Although upper sensors the ECU uses 90% of the time it still looks at the lower sensor from time to time. i would not remove them if I were you. Even non-foulders in my lower o2's caused me to run rich from time to time. I turned off the codes and removed the non foulers and the car runs much better.
Old Dec 28, 2011 | 05:03 PM
str8dum1's Avatar
str8dum1
it sounds like hes not using either up or down o2 sensors. can you even do that?
regardless he wont pass obd2 inspection in NY without them
Old Dec 28, 2011 | 07:59 PM
R350Zz33's Avatar
R350Zz33
Uprev turns off the 2 set of 02's I believe I had to get an uprev tune to pass inspection in ny what I'm asking is since there "off" can't I just remove them all together and when I get a retune they can just use my innovate wide band in its place since it has data logging
Old Dec 29, 2011 | 05:50 AM
Vince@R/TTuning's Avatar
Vince@R/TTuning
Vendor - Former Vendor
^^^ UPREV doesn't automatically turn any O2 sensors off. The only codes I turn off it the Cat efficiency codes and that's it. I still leave all the O2 sensors active....it makes for much better closed loop control and drivability....
Old Dec 29, 2011 | 07:37 AM
R350Zz33's Avatar
R350Zz33
Angry
OK thank you looks like I gotta go get some bungs welded or swap out or pick up some test pipes or high flows with extra bungs
Old Jan 1, 2012 | 03:10 PM
binder's Avatar
binder
save $140
I need to work for whoever your exhaust guy is if he charges 140$ to install 2 10$ exhaust bungs!!
seriously, before i moved my welder down here my room mate needed an o2 bung installed. Took it to an exhaust shop, 20$ and 10 minutes later it was done.
bcoffee20
Nov 19, 2015 06:39 PM
DaveFunction2ND
Mid-Atlantic
16
Feb 15, 2011 08:15 AM
ATX350
Texas
Jun 7, 2010 09:41 PM
Vince@R/TTuning
May 26, 2010 04:59 AM
