UpRev loading problem
Old May 12, 2013 | 11:30 AM
terrasmak's Avatar
Default UpRev loading problem
Tried CD003 and CD002 now, same results every time. The car is an 03 Touring 6MT.
Fans go on and stay on, car will not start. Once i pull the battery cable, the fans go off and i can start the car and try it again.
Old May 12, 2013 | 12:46 PM
denchan350gt's Avatar
denchan350gt
http://youtu.be/SNvj56KSCRA
is this a modified rom from your original tune? If so try reflashing your orginal maybe the file is corrupted.
This happened to me before once I reflashed with my orginal tune before any changes I made it worked.
Old May 12, 2013 | 02:04 PM
terrasmak's Avatar
It hasn't accepted any flash at all, license is still on the cable. I'm trying to load the initial software so I can actually start to play
Old May 13, 2013 | 12:58 PM
myork's Avatar
myork
You used to have an Accessport correct?
Stupid question, but when you flashed back to the stock ROM did you reset the ECU?
Old May 13, 2013 | 02:07 PM
terrasmak's Avatar
Never pulled the battery cable , bit drove the car a few times with the Cobb removed
Old May 15, 2013 | 10:24 PM
terrasmak's Avatar
Just got the file and tried to flash my friends car, would not load on his car either. I probably have a bad cable.
Old May 25, 2013 | 02:28 PM
Orestp's Avatar
Orestp
Have you resolved the Detect Flash Error?
This is exactly what happens when I try to flash - I have not successfully flashed my ECU with any file.
Here's what I've tried:
1. I've tried using another computer
2. I've charged the battery - voltage is about 14
3. I've tried it while having the battery charger hooked up
4. I've tried it with the headlamp fuse removed incase the voltage drop was having an effect - I have a US car, but had daytime running lights setup at a dealership - DTRL are required by law in Canada - not sure how the dealership set up the DTRL - there is no DTRL solenoid in the box where you would normally see it
5. I've tried it with the rad fan fuse removed incase the voltage drop was having an effect
6. I've tried it after running the car for a while
7. Sometimes Cipher finds a code: P0603 Internal Control Module Keep Alive Memory (KAM) Error which I can clear - sometimes Cipher does not return any codes.
8. I've attached a screenshot off Osiris right before I click Flash ECU
9. When I click Flash ECU - it loads the tune file and then when it should start the flash process, it returns "Detect Flash Error!" for about 2 seconds, and then changes to "Searching for ECU..." and then just stays that way (I've waited up to 10 minutes to see if it would change / do anything else)
10. Every time it fails - I disconnect / reconnect the battery to reset the ECU
11. After disconnecting / reconnecting the battery, the car starts and runs fine
Old May 25, 2013 | 04:12 PM
terrasmak's Avatar
Faulty cable, sent it back to uprev and they tested it. New one is on the way to me.
Old May 28, 2013 | 08:05 PM
terrasmak's Avatar
New cable, loaded and ready to start playing with the system.
Uriyo_
Sep 8, 2021 08:46 AM
