18.13:1 afr?
Old Mar 31, 2015 | 08:30 PM
Bigsyke's Avatar
Bigsyke
Default 18.13:1 afr?
Something seems off. I'm seeing allot of mid 16's during full throttle pulls.
Its a revup, so I have stock widebands. I didn't see any calibration options in the settings, which is strange because the manual calls for it.
Is this normal?
Old Apr 1, 2015 | 07:30 AM
seymore4's Avatar
seymore4
Professional
Hard to tell a lot from that limited data grab, but the 16~18:1 at that moment is normal. From what I can tell you were decelerating then hammered the gas, at that moment you will have funky readings. I think you are running lean tho, they should have corrected by 4300. You want to be right around 13:1, and B2 seems to be running leaner than B1. I would personally like to see less variance between them.
Old Apr 7, 2015 | 07:55 PM
Bigsyke's Avatar
Bigsyke
Update: I was running dangerously lean. High 14's-low 15's all the way through on multiple pulls.
Just a reminder, don't wait to get a tune! I only had a nismo exhaust, y-pipe and megan V2 test pipes at this time.
I'm into the 13's now.
bcoffee20
Nov 19, 2015 06:39 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
Bigsyke
Sep 11, 2015 06:19 PM
vics350
North East
36
Aug 27, 2004 06:15 PM
