Should a proper Fi tune pass emissions?
Old Apr 2, 2015 | 07:34 AM
jdm-v35's Avatar
jdm-v35
Default Should a proper Fi tune pass emissions?
Currently have an 03 G35 with procharger 12psi pullies(at sea level), but moved to colorado and have not got a retune yet, I have a tuning appointment in 2 weeks, but tried to pass emissions early and failed. First was my original hawaii map with lots of timing pulled. this failed for high hydrocarbons(7.3) and high co2. the next was a map I did with advanced timing and it only failed for hydrocarbons but by much less(3.8). Once I am able to get it properly dyno tuned for the altitude etc, should it usually be able to pass? with oem cats of course.
relevant mods are:
uprev tuner
procharger with 42/24 pullies
750cc RC injectors
return fuel system
oem headers and cats, 3" y pipe. oem midpipe, and custom axle back
Old Apr 2, 2015 | 08:01 AM
Conway_160's Avatar
Conway_160
Yes with proper tune you will pass.
Old Apr 2, 2015 | 08:08 AM
jdm-v35's Avatar
jdm-v35
cool thanks, hoping that will be the end of these problems!!also, conway, did you stick with the 40 ohm maf mod? or did you eventually get a new maf? debating whether to stick with it or go hpx
Old Apr 2, 2015 | 03:45 PM
Conway_160's Avatar
Conway_160
Still have the MAF mod.
Old Apr 4, 2015 | 11:52 AM
kilogram's Avatar
kilogram
My car tested cleaner than stock after I tuned it for the S/C.
Pulling timing will drastically increase HC. You're essentially dumping unburned fuel out the exhaust valves and letting the cats try to sort it out. They shouldn't be getting much into boost while driving it on the dyno though anyway. Mine were 20-40% better than when I had the car tested after we first moved here 3 years ago. Shouldn't be too hard to get it past emissions on a street tune.
Old Apr 4, 2015 | 03:49 PM
2bad240's Avatar
2bad240
Wow glad I don't have that type of emissions testing ours consist of connecting to the obd2 port and if all systems are ok it passes. Luckily for me all the systems are not available when they hook to it.
Old Apr 4, 2015 | 07:19 PM
jdm-v35's Avatar
jdm-v35
Cool thanks. Will definitely see how it does after I get the tune in 2 weeks. hopign it will sort it all out. yea the table with advanced timing only had hydrocarbons. the retarded timing had high HC and CO2 so Im guessing I need to be somewhere in the middle.
Old Apr 23, 2015 | 06:10 AM
jdm-v35's Avatar
jdm-v35
passed yesterday with no problems!! went from 7x the limits to 30% of the limit from just a tune.
Old Apr 23, 2015 | 06:21 AM
mvp2765's Avatar
mvp2765
Nice & Good to know!!
Old Apr 23, 2015 | 06:33 AM
jdm-v35's Avatar
jdm-v35
Yes im glad the struggle is over. I think My hawaii tune was just horrible here. with the loss of boost due to altitude the car was running very rich and too much timing was pulled for the amount of boost im making here so with that combination it ran badly. Now I can work on making more power.
Old Apr 23, 2015 | 08:13 PM
bealljk's Avatar
bealljk
thumbs up!
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
