UTEC broken??
Old May 15, 2015 | 05:09 PM
trusovici's Avatar
trusovici
Default UTEC broken??
was wondering if anyone had any advice for me. I bought a used utec a while back, just installed it today. The car starts and idles fine but the check engine, tcs off, and slip lights all come on and i can not rev past 2k rpm. I can communicate with it through hyperterminal. I tried a few different maps and even when i use the 0 map the problem remains. Any help would be appreciated.
Old May 19, 2015 | 06:54 AM
trusovici's Avatar
trusovici
tried grounding everything (molex, utec body), set parameters, loaded base maps etc. stock ecu runs fine. Can anyone please help me before i give up on this?
Old May 21, 2015 | 09:39 AM
str8dum1's Avatar
str8dum1
what codes? does everything go back to normal when you run just the stock ecu?
Old May 22, 2015 | 07:41 PM
trusovici's Avatar
trusovici
yes it runs fine if i run stock ecu.
Old May 23, 2015 | 10:33 PM
seymore4's Avatar
seymore4
Professional
Why not just run Uprev???
Old Aug 12, 2015 | 08:12 PM
trusovici's Avatar
trusovici
bump, anyone got an answer to this.
Old Aug 18, 2015 | 05:38 PM
Boingo's Avatar
Boingo
Did you try and reflash the firmware on the UTEC? What version is shown in upper right? Last update was v2.8. Also, check the connection harnesses again to make sure they are all properly seated and locked in position. Beware - the reflash is a pain and took me about 6 attempts to find settings that worked. Baud rate - lower than TXS manual recommends, and I have to uncheck error checking. Otherwise, it would only get about 50% of load then crash.
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
Dymsi
Sep 29, 2015 11:32 AM
