Technosquare Reflash question
This is probably a really stupid question but:
If your engine is completely stock and you have your ECU reflashed or whatever technosquare does...do you see HP and TQ gains? |
24 views and no short answer...i don't mind if you flame me (pause)...i'm sure its a dumb question
I think in some of the threads, people said that you might gain a bit, but the two things that it does that I like are:
1. 8000RPM redline 2. ability to open up your throttle 100% right when press it to the floor... and not gradually as it does with it being stock |
so minimal power gains?
It's pretty retarded to do it stock if you plan on getting modifications in teh form of bolt ons cause you will jsut have to reflash again but if you plan to stay stock performance wise and jsut want the car to have a better response with some power gains go for the reflash stock.
you probably won't gain much, but you'll gain something along with some extra mpg city driving.
how much does it cost?
100 million dollars |
^^^hahahahaha
lol
Originally Posted by JETPILOT
8000RPM redline? There were 3 different motors used in these cars. Which one were you refering to?
It doesn't raise the redline to 8000RPM. The engines redline is what the engine is safely able to rev to. The stock valve springs aren't going to handle anything near 8000 RPM. There is no point to reving to 8000RPM if you aren't making power up there.
OK..... Thanks for the tutorial. You go on believing that. Just don't expect anyone else to believe it.
i believe the rev limiter is set to 7200 instead of 6600 on the 287 motor... not 8000
speed governor is removed too
HR engine gets its fuel cut set to 8000 with the reflash. |
